intprefix_set_promiscuous(gld_mac_info_t *macinfo,intpromiscflag);
gldm_set_promiscuous() enables and disables promiscuous mode. This function is called whenever GLD wants to enable or disable the reception of all packets on the medium, or of all multicast packets on the medium. If the second argument promiscflag is set to the value of GLD_MAC_PROMISC_PHYS, then the function enables physical-level promiscuous mode, resulting in the reception of all packets on the medium. If promiscflag is set to GLD_MAC_PROMISC_MULTI, then reception of all multicast packets will be enabled. If promiscflag is set to GLD_MAC_PROMISC_NONE, then promiscuous mode is disabled.
In the case of a request for promiscuous multicast mode, drivers for devices that have no multicast-only promiscuous mode must set the device to physical promiscuous mode to ensure that all multicast packets are received. In this case the routine should return GLD_SUCCESS. The GLD software filters out any superfluous packets. If sufficient resources are currently not available to carry out the request, the function should return GLD_NORESOURCES. It should return GLD_NOTSUPPORTED if the requested function is not supported.
For forward compatibility, gldm_set_promiscuous() routines should treat any unrecognized values for promiscflag as though they were GLD_MAC_PROMISC_PHYS.
