The following arguments are used by the GLD routines.
Pointer to a gld_mac_info(9S) structure.
Pointer to the beginning of a character array containing a valid MAC address. The array will be of the length specified by the driver in the gldm_addrlen element of the gld_mac_info(9S) structure.
Pointer to the beginning of a character array containing a multicast, group, or functional address. The array will be of the length specified by the driver in the gldm_addrlen element of the gld_mac_info(9S) structure.
Flag indicating whether reception of the multicast address is to be enabled or disabled. This argument is specified as GLD_MULTI_ENABLE or GLD_MULTI_DISABLE.
Flag indicating what type of promiscuous mode, if any, is to be enabled. This argument is specified as GLD_MAC_PROMISC_PHYS, GLD_MAC_PROMISC_MULTI, or GLD_MAC_PROMISC_NONE.
gld_ioctl() uses mp as a pointer to a STREAMS message block containing the ioctl to be executed. gldm_send() uses it as a pointer to a STREAMS message block containing the packet to be transmitted. gld_recv() uses it as a pointer to a message block containing a received packet.
Pointer to a gld_stats(9S) structure to be filled in with the current values of statistics counters.
Pointer to the queue(9S) structure to be used in the reply to the ioctl.
Pointer to the device's dev_info structure.
Device interface name.
