This section describes a number of SPARC processor-specific topics including data alignment, byte ordering, register windows, and availability of floating-point instructions. For information on IA processor-specific topics, see IA Processor Issues.
Drivers should never perform floating-point operations, as they are not supported in the kernel.
All quantities must be aligned on their natural boundaries. Using standard C data types:
short integers are aligned on 16-bit boundaries.
int integers are aligned on 32-bit boundaries.
long integers are aligned on either 32-bit boundaries or 64-bit boundaries, depending on whether the data model of the kernel is 64-bit or 32-bit. For information on data models, see Appendix C, Making a Device Driver 64-Bit Ready .
long long integers are aligned on 64-bit boundaries.
Usually, the compiler handles alignment issues. However, driver writers are more likely to be concerned about alignment as they must use the proper data types to access their device. Because device registers are commonly accessed through a pointer reference, drivers must ensure that pointers are properly aligned when accessing the device.
Because of the data alignment restrictions imposed by the SPARC processor, C structures also have alignment requirements. Structure alignment requirements are imposed by the most strictly-aligned structure component. For example, a structure containing only characters has no alignment restrictions, while a structure containing a long long member must be constructed to guarantee that this member falls on a 64-bit boundary.
The SPARC processor uses big-endian byte ordering; in other words, the most significant byte (MSB) of an integer is stored at the lowest address of the integer.
SPARC processors use register windows. Each register window consists of 8 in registers, 8 local registers, and 8 out registers (which are the in registers of the next window). There are also 8 global registers. The number of register windows ranges from 2 to 32, depending on the processor implementation.
Because drivers are normally written in C, the compiler usually hides the fact that register windows are used. However, you might have to use them when debugging the driver.
The Version 7 SPARC processors do not have multiply or divide instructions. These instructions are emulated in software and should be avoided. Because a driver cannot determine whether it is running on a Version 7, Version 8, or Version 9 processor, intensive integer multiplication and division should be avoided if possible. Instead, use bitwise left and right shifts to multiply and divide by powers of two.
The SPARC Architecture Manual, Version 9, contains more specific information on the SPARC CPU. The SPARC Compliance Definition, Version 2.4, contains details of the SPARC V9 application binary interface (ABI). It describes the 32–bit SPARC V8 ABI and the 64–bit SPARC V9 ABI. You can obtain this document from SPARC International at http://www.sparc.com.
