The SBus has 32 address bits, as described in the SBus Specification. Table A–2 describes how the Ultra 2 uses the address bits.
Table A–2 Ultra 2 SBus Address Bits|
Bits |
Description |
0 - 27 |
These bits are the SBus address lines used by an SBus card to address the contents of the card. |
28 - 31 |
Used by the CPU to select one of the SBus slots. These bits generate the SlaveSelect lines. |
This addressing scheme yields the Ultra 2 addresses shown in Table A–1. Other implementations might use a different number of address bits.
The Ultra 2 has seven SBus slots, four of which are physical. Slots 0 through 3 are available for SBus cards. Slots 4-12 are reserved. The slots are used in the following way:
Slots 0–3 are physical slots that have DMA-master capability.
Slots D, E, and F are not actual physical slots, but refer to the onboard direct memory access (DMA), SCSI, Ethernet, and audio controllers. For convenience, these are viewed as being plugged into slots D, E, and F.
Some SBus slots are slave-only slots. Drivers that require DMA capability should use ddi_slaveonly(9F) to determine if their device is in a DMA-capable slot. For an example of this function, see The attach() Entry Point.
