SPARC processors use register windows. Each register window consists of 8 in registers, 8 local registers, and 8 out registers (which are the in registers of the next window). There are also 8 global registers. The number of register windows ranges from 2 to 32, depending on the processor implementation.
Because drivers are normally written in C, the compiler usually hides the fact that register windows are used. However, you might have to use them when debugging the driver.
