There are two common ways in which buses implement interrupts: vectored and polled. Both methods commonly supply a bus-interrupt priority level. However, vectored devices also supply an interrupt vector; polled devices do not.
Buses prioritize device interrupts at one of several bus-interrupt levels. These bus interrupt levels are then mapped to different processor-interrupt levels. A bus interrupt level that maps to a CPU interrupt priority level above the scheduler priority level is called a high-level interrupt. High-level interrupt handlers are restricted in what DDI interfaces they can call. In particular, the only DDI routines that high-level interrupt handlers are allowed to call are:
mutex_enter(9F) and mutex_exit(9F) on a mutex initialized with an iblock cookie associated with the high-level interrupt
ddi_trigger_softintr(9F)
the ddi_getX/ddi_putX families of routines (such as ddi_get8(9F))
A bus-interrupt level by itself does not determine whether a device interrupts at high level: a given bus-interrupt level may map to a high-level interrupt on one platform, but map to an ordinary interrupt on another platform.
The driver can choose whether to support devices that have high-level interrupts, but it always has to check—it cannot assume that its interrupts are not high level. The function ddi_intr_hilevel(9F), given an interrupt number, returns a value indicating whether the interrupt is high level.
The only information the system has about a device interrupt is either the bus interrupt priority level (IPL, on an SBus in a SPARC machine, for example) or the interrupt request number (IRQ on an ISA bus in an IA machine, for example).
When an interrupt handler is registered, the system adds the handler to a list of potential interrupt handlers for each IPL or IRQ. Once the interrupt occurs, the system must determine which device, of all the devices associated with a given IPL or IRQ, actually interrupted. It does this by calling all the interrupt handlers for the designated IPL or IRQ, until one handler claims the interrupt.
The SBus, ISA, EISA, and PCI buses are capable of supporting polled interrupts.
The Solaris 9 DDI/DKI supports software interrupts, also known as soft interrupts. Soft interrupts are initiated by software, rather than by a hardware device. Handlers for these interrupts must also be added to and removed from the system. Soft interrupt handlers run in interrupt context and therefore can be used to do many of the tasks that belong to an interrupt handler.
Hardware interrupt handlers are supposed to perform their tasks quickly, since they may suspend other system activity while running. This is particularly true for high-level interrupt handlers, which operate at priority levels greater than that of the system scheduler. High-level interrupt handlers mask the operations of all lower-priority interrupts—including those of the system clock. Consequently, the interrupt handler must avoid involving itself in an activity (such as acquiring a mutex) that might cause it to sleep.
If the handler sleeps, then the system may hang because the clock is masked and incapable of scheduling the sleeping thread. For this reason, high-level interrupt handlers normally perform a minimum amount of work at high-priority levels and delegate remaining tasks to software interrupts, which run below the priority level of the high-level interrupt handler. Because software interrupt handlers run below the priority level of the system scheduler, they can do the work that the high-level interrupt handler was incapable of doing.
