This appendix provides information for device driver writers who are converting their device drivers to support the 64-bit kernel. It presents the differences between 32-bit and 64-bit device drivers and describes the steps to convert 32-bit device drivers to 64-bit. This information is specific to regular character and block device drivers only.
This appendix provides information on the following subjects:
For drivers that only need support for the 32-bit kernel, existing 32-bit device drivers will continue to work without recompilation. However, most device drivers require some changes to run correctly in the 64-bit kernel, and all device drivers require recompilation to create a 64-bit driver module. The information in this appendix will help you to enable drivers for 32-bit and 64-bit environments to be generated from common source code, thus increasing code portability and reducing the maintenance effort.
Before starting to clean up a device driver for the 64-bit environment, you should understand how the 32-bit environment differs from the 64-bit environment. In particular, you must be familiar with the C language data type models ILP32 and LP64, and to be aware of driver-specific issues. Driver-specific issues are the subject of this appendix, while more general issues are covered extensively in Solaris 64-bit Developer's Guide.
In addition to general code cleanup to support the data model changes for LP64, driver writers have to provide support for both 32-bit and 64-bit applications.
The ioctl(9E), devmap(9E), and mmap(9E) entry points enable data structures to be shared directly between applications and device drivers. If those data structures change size between the 32-bit and 64-bit environments, then the entry points must be modified so that the driver can determine whether the data model of the application is the same as that of the kernel. When the data models differ, data structures can be adjusted. See I/O Control Support for 64-Bit Capable Device Drivers, 32–bit and 64–bit Data Structure Macros, and Associating Kernel Memory With User Mappings.
Practically speaking, in many drivers, only a few ioctls need this kind of handling; the others will work without change as long as they pass around data structures that do not change in size.
The sections below provide information on converting drivers to run in a 64-bit environment. Driver writers might need to do one or more of the following:
Use fixed-width types for hardware registers.
Use fixed-width common access functions.
Check and extend use of derived types.
Check changed fields within DDI data structures.
Check changed arguments of DDI functions.
Modify the driver entry points that handle user data, where needed.
These steps are explained in detail below.
After each step is complete, fix all compiler warnings, and use lint to look for other problems. The SC5.0 (or newer) version of lint should be used with -Xarch=v9 and -errchk=longptr64 specified to find 64–bit problems. See the notes on using and interpreting the output of lint in the Solaris 64-bit Developer's Guide.
Do not ignore compilation warnings during conversion for LP64. Even those that were safe to ignore previously in the ILP32 environment might now indicate a more serious problem.
After all the steps are complete, compile and test the driver as both a 32-bit and 64-bit modules.
Many device drivers that manipulate hardware devices use C data structures to describe the layout of the hardware. In the LP64 data model, data structures that use long
or unsigned long to define hardware registers are almost certainly incorrect, because long
is now a 64-bit
quantity. Start by including <sys/inttypes.h>, and update this class of data structure to use int32_t
or uint32_t
instead of long
for 32-bit device data. This preserves the binary layout of 32-bit data structures. For example, change:
struct device_regs { ulong_t addr; uint_t count; }; /* Only works for ILP32 compilation */
to:
struct device_regs { uint32_t addr; uint32_t count; }; /* Works for any data model */
The Solaris DDI permits device registers to be accessed by access functions for portability to multiple platforms. Previously, the DDI common access functions specified the size of data in terms of bytes, words, and so on. For example, ddi_getl(9F) is used to access 32-bit quantities. This function is not available in the 64-bit DDI environment, and has been replaced by versions that are specified using the number of bits that they manipulate.
These routines were added to the 32-bit kernel in the Solaris 2.6 operating environment, to permit their early adoption by driver writers. For example, to be portable to both 32-bit and 64-bit kernels, the driver must use ddi_get32(9F) to access 32-bit data rather than ddi_getl(9F).
The entire set of common access routines is replaced by their fixed-width equivalents. See the ddi_get8(9F), ddi_put8(9F), ddi_rep_get8(9F), and ddi_rep_put8(9F) man pages for details.
System-derived types, such as size_t
, should be used where possible so that the resulting variables make sense when passed between functions. The new derived types uintptr_t
or intptr_t
should be used as the integral type for pointers.
Fixed-width integer types are useful for representing explicit sizes of binary data structures or hardware registers, while fundamental C language data types, such as int
, can still be used for loop counters or file descriptors.
Some system-derived types represent 32-bit quantities on a 32-bit system but represent 64-bit quantities on a 64-bit system. Derived types that change size in this way include: clock_t
, daddr_t
, dev_t
, ino_t
, intptr_t
, off_t
, size_t
, ssize_t
, time_t
, uintptr_t
, and timeout_id_t
Drivers that use these derived types should pay particular attention to their use, particularly if they are assigning these values to variables of another derived type, such as a fixed-width type.
The data types of some of the fields within DDI data structures, such as buf(9S), have been changed. Drivers that use these data structures should make sure that these fields are being used appropriately. The data structures and the fields that were changed in a significant way are listed below.
size_t b_bcount; /* was type unsigned int */ size_t b_resid; /* was type unsigned int */ size_t b_bufsize; /* was type long */
The fields changed here pertain to transfer size, which can now exceed more than 4 Gbytes.
The ddi_dma_attr(9S) structure defines attributes of the DMA engine and the device. Because these attributes specify register sizes, fixed-width data types have been used instead of fundamental types.
uint32_t dmac_address; /* was type unsigned long */ size_t dmac_size; /* was type u_int */
The ddi_dma_cookie(9S) structure contains a 32-bit DMA address, so a fixed-width data type has been used to define it. The size has
been redefined as size_t
uint_t sts_rqpkt_state; /* was type u_long */ uint_t sts_rqpkt_statistics; /* was type u_long */
These fields in the structure do not need to grow and have been redefined as 32-bit quantities.
uint_t pkt_flags; /* was type u_long */ int pkt_time; /* was type long */ ssize_t pkt_resid; /* was type long */ uint_t pkt_state; /* was type u_long */ uint_t pkt_statistics; /* was type u_long */
Because the pkt_flags
, pkt_state
, and pkt_statistics
fields in the scsi_pkt(9S) structure do not need
to grow, they have been redefined as 32-bit integers. The data transfer size pkt_resid field does grow and has been redefined as ssize_t
Some DDI function argument data types have been changed. These routines are listed below.
struct buf *getrbuf(int sleepflag);
In previous releases, sleepflag was defined as a type long
int drv_getparm(unsigned int parm, void *value_p);
In previous releases, value_p was defined as type unsigned long
In the 64-bit kernel, drv_getparm(9F) can be used to fetch both 32-bit and 64-bit quantities, yet the interface does not define the data types of these quantities, which encourages simple programming errors.
The following new routines offer a safer alternative:
clock_t ddi_get_lbolt(void); time_t ddi_get_time(void); cred_t *ddi_get_cred(void); pid_t ddi_get_pid(void);
Driver writers are strongly urged to use these routines instead of drv_getparm(9F).
void delay(clock_t ticks); timeout_id_t timeout(void (*func)(void *), void *arg, clock_t ticks);
The ticks argument to the delay(9F) and timeout(9F) routines has been changed from long
to clock_t
struct map *rmallocmap(size_t mapsize); struct map *rmallocmap_wait(size_t mapsize);
The mapsize argument to thermallocmap(9F) and rmallocmap_wait(9F) routines has been changed from ulong_t
to size_t
struct buf *scsi_alloc_consistent_buf(struct scsi_address *ap, struct buf *bp, size_t datalen, uint_t bflags, int (*callback )(caddr_t), caddr_t arg);
In previous releases, datalen was defined as an int
and bflags was defined as a ulong
int uiomove(caddr_t address, size_t nbytes, enum uio_rw rwflag, uio_t *uio_p);
The nbytes argument was defined as a type long
, but because it represents a size in bytes, size_t
is more appropriate.
int cv_timedwait(kcondvar_t *cvp, kmutex_t *mp, clock_t timeout); int cv_timedwait_sig(kcondvar_t *cvp, kmutex_t *mp, clock_t timeout);
In previous releases, the timeout argument to the cv_timedwait(9F) and cv_timedwait_sig(9F) routines was defined to be of type long
. Because they represent time in ticks, clock_t
int ddi_device_copy(ddi_acc_handle_t src_handle, caddr_t src_addr, ssize_t src_advcnt, ddi_acc_handle_t dest_handle, caddr_t dest_addr, ssize_t dest_advcnt, size_t bytecount, uint_t dev_datasz);
The src_advcnt, dest_advcnt, dev_datasz arguments have changed type. These were previously defined as long
, long
, and ulong_t
respectively.
int ddi_device_zero(ddi_acc_handle_t handle, caddr_t dev_addr, size_t bytecount, ssize_t dev_advcnt, uint_t dev_datasz):
In previous releases, dev_advcnt was defined as a type long
and dev_datasz as a ulong_t
int ddi_dma_mem_alloc(ddi_dma_handle_t handle, size_t length, ddi_device_acc_attr_t *accattrp, uint_t flags, int (*waitfp)(caddr_t), caddr_t arg, caddr_t *kaddrp, size_t *real_length, ddi_acc_handle_t *handlep);
In previous releases, length, flags, and real_length were defined with types uint_t
, ulong_t
, and uint_t *
If a device driver shares data structures that contain long
s or pointers with a 32-bit application using ioctl(9E), devmap(9E), or mmap(9E),
and the driver is recompiled for a 64-bit kernel, the binary layout of data structures will be incompatible. If a field is currently defined in terms of type long
, and there is no actual need for 64-bit data items, change the data structure to use data types that remain as 32–bit quantities
(int
and unsigned
int
). Otherwise, the driver needs to be aware of the different structure shapes for ILP32 and LP64 and determine whether there is a model mismatch between the application and the kernel.
To handle potential data model differences, the ioctl(), devmap(), and mmap() driver entry points, which interact directly with user applications, need to be written to determine whether the argument came from an application using the same data model as the kernel.
To determine whether there is a model mismatch between the application and the driver, the driver uses the FMODELS mask to determine the model type from the ioctl() mode argument. The following values are OR-ed into mode to identify the application data model:
The code examples in I/O Control Support for 64-Bit Capable Device Drivers show how this can be handled using ddi_model_convert_from(9F).
To enable a 64-bit driver and a 32-bit application to share memory, the binary layout generated by the 64-bit driver must be the same as consumed by the 32-bit application. The mapped memory being exported to the application might need to contain data-model-dependent data structures.
Few memory mapped devices face this problem because the device registers do not change size when the kernel data model changes. However, some pseudo-devices that export mappings to the user address space might want to export different data structures to ILP32 or LP64 applications. To determine whether there is a data model mismatch, devmap(9E) uses the model parameter to describe the data model expected by the application. The model parameter is set to one of the following:
The model parameter can be passed untranslated to the ddi_model_convert_from(9F) routine or to STRUCT_INIT(). See 32–bit and 64–bit Data Structure Macros.
Because mmap(9E) does not have a parameter that can be used to pass data model information, the driver's mmap(9E) entry point can be written to use the new DDI function ddi_model_convert_from(9F). This function returns one of the following values to indicate the application's data type model:
DDI_FAILURE – Function was not called from mmap(9E)
As with ioctl() and devmap(), the model bits can be passed to ddi_model_convert_from(9F) to determine whether data conversion is necessary, or the model can be handed to STRUCT_INIT().
Alternatively, migrate the device driver to support the devmap(9E) entry point.
Many ioctl(9E) operations are common to a class of device drivers. For example, most disk drivers implement many of the dkio(7I) family of ioctl()s. Many of these interfaces copy in or copy out data structures from the kernel, and some of these data structures have changed size in the LP64 data model. The following section lists the ioctls that now require explicit conversion in 64-bit driver ioctl routines for the dkio, fdio(7I), fbio(7I), cdio(7I), and mtio(7I) families of ioctl()s.
ioctl command |
Affected data structure |
Reference |
DKIOCGAPART DKIOCSAPART |
struct dk_map struct dk_allmap |
dkio(4) |
DKIOGVTOC DKIOSVTOC |
struct partition struct vtoc |
dkio(4) |
FBIOPUTCMAP FBIOGETCMAP |
struct fbcmap |
fbio(4) |
FBIOPUTCMAPI FBIOGETCMAPI |
struct fbcmap_i |
fbio(4) |
FBIOSCURSOR FBIOSCURSOR |
struct fbcursor |
fbio(4) |
CDROMREADMODE1 CDROMREADMODE2 |
struct cdrom_read |
cdio(4) |
CDROMCDDA |
struct cdrom_cdda |
cdio(4) |
CDROMCDXA |
struct cdrom_cdxa |
cdio(4) |
CDROMSUBCODE |
struct cdrom_subcode |
cdio(4) |
FDIOCMD |
struct fd_cmd |
fdio(4) |
FDRAW |
struct fd_raw |
fdio(4) |
MTIOCTOP |
struct mtop |
mtio(4) |
MTIOCGET |
struct mtget |
mtio(4) |
MTIOCGETDRIVETYPE |
struct mtdrivetype_request |
mtio(4) |
USCSICMD |
struct uscsi_cmd |
scsi(4) |
The nblocks property is exported by each slice of a block device driver. It contains the number of 512 byte blocks that each slice of the device can support. The nblocks property is defined as a signed 32-bit quantity, which limits the maximum size of a slice to 1 Tbyte.
Disk devices that provide more than 1 Tbyte of storage per disk must define the Nblocks property, which should still contain the number of 512 byte blocks that the device can support. However, Nblocks is a signed 64-bit quantity, which removes any practical limit on disk space.
The nblocks property is now deprecated; all disk devices should provide the Nblocks property.
