Many ioctl(9E) operations are common to a class of device drivers. For example, most disk drivers implement many of the dkio(7I) family of ioctl()s. Many of these interfaces copy in or copy out data structures from the kernel, and some of these data structures have changed size in the LP64 data model. The following section lists the ioctls that now require explicit conversion in 64-bit driver ioctl routines for the dkio, fdio(7I), fbio(7I), cdio(7I), and mtio(7I) families of ioctl()s.
ioctl command |
Affected data structure |
Reference |
DKIOCGAPART DKIOCSAPART |
struct dk_map struct dk_allmap |
dkio(4) |
DKIOGVTOC DKIOSVTOC |
struct partition struct vtoc |
dkio(4) |
FBIOPUTCMAP FBIOGETCMAP |
struct fbcmap |
fbio(4) |
FBIOPUTCMAPI FBIOGETCMAPI |
struct fbcmap_i |
fbio(4) |
FBIOSCURSOR FBIOSCURSOR |
struct fbcursor |
fbio(4) |
CDROMREADMODE1 CDROMREADMODE2 |
struct cdrom_read |
cdio(4) |
CDROMCDDA |
struct cdrom_cdda |
cdio(4) |
CDROMCDXA |
struct cdrom_cdxa |
cdio(4) |
CDROMSUBCODE |
struct cdrom_subcode |
cdio(4) |
FDIOCMD |
struct fd_cmd |
fdio(4) |
FDRAW |
struct fd_raw |
fdio(4) |
MTIOCTOP |
struct mtop |
mtio(4) |
MTIOCGET |
struct mtget |
mtio(4) |
MTIOCGETDRIVETYPE |
struct mtdrivetype_request |
mtio(4) |
USCSICMD |
struct uscsi_cmd |
scsi(4) |
The nblocks property is exported by each slice of a block device driver. It contains the number of 512 byte blocks that each slice of the device can support. The nblocks property is defined as a signed 32-bit quantity, which limits the maximum size of a slice to 1 Tbyte.
Disk devices that provide more than 1 Tbyte of storage per disk must define the Nblocks property, which should still contain the number of 512 byte blocks that the device can support. However, Nblocks is a signed 64-bit quantity, which removes any practical limit on disk space.
The nblocks property is now deprecated; all disk devices should provide the Nblocks property.
