In traditional UNIX systems, every section of kernel code runs until it explicitly gives up the processor by calling sleep(1) or is interrupted by hardware. This is not true in the Solaris operating environment. A kernel thread can be preempted at any time to run another thread. Because all kernel threads share kernel address space and often need to read and modify the same data, the kernel provides a number of locking primitives to prevent threads from corrupting shared data. These mechanisms include mutual exclusion locks (or mutex), readers/writer locks, and semaphores.
The storage class of data is a guide to whether the driver might need to take explicit steps to control access to the data. The three types of data storage classes are:
Automatic (stack) data – Every thread has a private stack, so drivers never need to lock automatic variables.
Global and static data – Global and static data can be shared by any number of threads in the driver; the driver might need to lock this type of data at times.
Kernel heap data – Any number of threads in the driver might share kernel heap data, such as data allocated by kmem_alloc(9F). If this data is shared, the driver needs to protect it at times.
A mutual-exclusion lock, or mutex, is usually associated with a set of data and regulates access to that data. Mutexes provide a way to allow only one thread at a time access to that data.
Table 3–1 Mutex Routines|
Name |
Description |
mutex_init(9F) |
Initializes a mutex |
mutex_destroy(9F) |
Releases any associated storage |
mutex_enter(9F) |
Acquires a mutex |
mutex_tryenter(9F) |
Acquires a mutex if available; but does not block |
mutex_exit(9F) |
Releases a mutex |
mutex_owned(9F) |
Tests to determine if the mutex is held by the current thread. To be used in ASSERT(9F) only |
Device drivers usually allocate a mutex for each driver data structure. The mutex is typically a field in the structure and is of type kmutex_t. mutex_init(9F) is called to prepare the mutex for use. This is usually done at attach(9E) time for per-device mutexes and _init(9E) time for global driver mutexes.
For example,
struct xxstate *xsp; ... mutex_init(&xsp->mu, NULL, MUTEX_DRIVER, NULL); ...
For a more complete example of mutex initialization, see Chapter 5, Driver Autoconfiguration.
The driver must destroy the mutex with mutex_destroy(9F) before being unloaded. This is usually done at detach(9E) time for per-device mutexes and _fini(9E) time for global driver mutexes.
Every section of the driver code that needs to read or write the shared data structure must do the following:
Acquire the mutex
Access the data
Release the mutex
The scope of a mutex—the data it protects—is entirely up to the programmer. A mutex protects some particular data structure because the programmer chooses to do so and uses it accordingly. A mutex protects a data structure only if every code path that accesses the data structure does so while holding the mutex.
A readers/writer lock regulates access to a set of data. The readers/writer lock is so called because many threads can hold the lock simultaneously for reading, but only one thread can hold it for writing.
Most device drivers do not use readers/writer locks. These locks are slower than mutexes and provide a performance gain only when protecting data that is not frequently written but is commonly read by many concurrent threads. In this case, contention for a mutex could become a bottleneck, so using a readers/writer lock might be more efficient. The readers/writer functions are summarized in the following table. See the rwlock(9F) man page for detailed information.
Table 3–2 Readers/Writer Locks|
Name |
Description |
rw_init(9F) |
Initializes a readers/writer lock |
rw_destroy(9F) |
Destroys a readers/writer lock |
rw_enter(9F) |
Acquires a readers/writer lock |
rw_tryenter |
Attempts to acquire a reader/writer lock without waiting |
rw_tryupgrade(9F) |
Attempts to upgrade readers/writer lock holding from reader to writer |
rw_downgrade(9F) |
Downgrades a readers/writer lock holding from writer to reader |
rw_exit(9F) |
Releases a readers/writer lock |
rw_read_locked(9F) |
Determines whether readers/writer lock is held for read or write |
Counting semaphores are available as an alternative primitive for managing threads within device drivers. See the semaphore(9F) man page for more information.
Table 3–3 Semaphores|
Name |
Description |
sema_init(9F) |
Initialize a semaphore |
sema_destroy(9F) |
Destroys a semaphore |
sema_p(9F) |
Decrement semaphore and possibly block |
sema_tryp(9F) |
Attempt to decrement semaphore, but do not block |
sema_p_sig(9F) |
Decrement semaphore, but do not block if signal is pending |
sema_v(9F) |
Increment semaphore and possibly unblock waiter |
