System power management passes the command DDI_SUSPEND to the detach(9E) driver entry point to request the driver to save the device hardware state. It passes the command DDI_RESUME to the attach(9E) driver entry point to request the driver to restore the device hardware state.
The syntax for detach(9E) is as follows:
int detach(dev_info_t *dip, ddi_detach_cmd_t cmd);
If a device has a reg property or a pm-hardware-state property with a value of needs-suspend-resume, then the framework calls into the driver's detach(9E) entry point to allow the driver to save the hardware state of the device to memory so that it can be restored after the system power returns. To process the DDI_SUSPEND command, detach(9E) must do the following:
Block further operations from being initiated until the device is resumed (except for dump(9E) requests).
Wait until outstanding operations have completed (or abort them if they can be restarted).
Cancel pending timeouts and callbacks.
Save any volatile hardware state to memory. The state includes the contents of device registers, and may also include downloaded firmware.
If for some reason the driver is not able to suspend the device and save its state to memory, then it must return DDI_FAILURE, and the framework aborts the system power management operation.
In some cases, powering down a device involves certain risks. For example, if a tape drive is powered off with a tape inside it, the tape can be damaged. In such a case, attach(9E) should:
Call ddi_removing_power(9F) to determine if a DDI_SUSPEND command may cause power to be removed from the device.
Determine if power removal will cause problems.
Dump requests must be honored. The framework uses the dump(9E) entry point to write out the state file containing the contents of memory. See the dump(9E) man page for restrictions imposed on the device driver when using this entry point.
If the device implements power-manageable components, the device may have had its state saved and powered off when its detach(9E) entry point is called with the DDI_SUSPEND command. In this case the driver should cancel pending timeouts and suppress the call to pm_raise_power(9F) (except for dump(9E) requests) until the device is resumed by a call to attach(9E) with a command of DDI_RESUME. The driver must keep sufficient track of its state to be able to deal appropriately with this possibility. Example 9–6 shows an example of a detach(9E) routine with the DDI_SUSPEND command implemented.
int
xxdetach(dev_info_t *dip, ddi_detach_cmd_t cmd)
struct xxstate *xsp;
int instance;
instance = ddi_get_instance(dip);
xsp = ddi_get_soft_state(statep, instance);
switch (cmd) {
case DDI_DETACH:
case DDI_SUSPEND:
* We do not allow DDI_SUSPEND if power will be removed and
* we have a device that damages tape when power is removed
* We do support DDI_SUSPEND for Device Reconfiguration.
if (ddi_removing_power(dip) && xxdamages_tape(dip))
return (DDI_FAILURE);
mutex_enter(&xsp->mu);
xsp->xx_suspended = 1; /* stop new operations */
* Sleep waiting for all the commands to be completed
* If a callback is outstanding which cannot be cancelled
* then either wait for the callback to complete or fail the
* suspend request
* This section is only needed if the driver maintains a
* running timeout
if (xsp->xx_timeout_id) {
timeout_id_t temp_timeout_id = xsp->xx_timeout_id;
xsp->xx_timeout_id = 0;
mutex_exit(&xsp->mu);
untimeout(temp_timeout_id);
if (!xsp->xx_state_saved) {
* Save device register contents into
* xsp->xx_device_state
return (DDI_SUCCESS);
default:
The syntax for attach(9E) is as follows:
int attach(dev_info_t *dip, ddi_attach_cmd_t cmd);
When power is restored to the system, each device with a reg property or with a pm-hardware-state property of value needs-suspend-resume has its attach(9E) entry point called with a command value of DDI_RESUME. If the system shutdown was aborted for some reason, each driver that was suspended is called to resume, even though the power has not been shut off. Consequently, the resume code in attach(9E) must make no assumptions about the state of the hardware; it may or may not have lost power.
The power management framework considers the power level of the components to be unknown at DDI_RESUME time. Depending on the nature of the device, the driver writer has two choices:
If the driver can determine the actual power level of the components of the device without powering them up (by reading a register, for example), then the driver should notify the framework of the power level of each component by calling pm_power_has_changed(9F).
If it cannot determine the power levels of the components, then the driver should mark each component internally as unknown and call pm_raise_power(9F) before the first access to each one.
Example 9–7 shows an example of an attach(9E) routine with the DDI_RESUME command.
int
xxattach(devinfo_t *dip, ddi_attach_cmd_t cmd)
int instance;
switch (cmd) {
case DDI_ATTACH:
case DDI_RESUME:
if (xsp->xx_pm_state_saved) {
* Restore device register contents from
* This section is optional and only needed if the
* driver maintains a running timeout
xsp->xx_timeout_id = timeout(...);
xsp->xx_suspended = 0; /* allow new operations */
cv_broadcast(&xsp->xx_suspend_cv);
/* If it is possible to determine in a device-specific
* way what the power levels of components are without
* powering the components up,
* then the following code is recommended
for (i = 0; i < num_components; i++) {
xsp->xx_power_level[i] = xx_get_power_level(dip, i);
if (xsp->xx_power_level[i] != XX_LEVEL_UNKNOWN)
(void) pm_power_has_changed(dip, i,
xsp->xx_power_level[i]);
return(DDI_SUCCESS);
default:
return(DDI_FAILURE);
The detach(9E) and attach(9E) interfaces may also be used to resume a system that has been quiesced.
