A kstat or kernel statistic is a data structure that records the time, counters, various measurements, and other data regarding the use of a device. kstats are stored as NULL-terminated linked lists.
Table 4–2 kstat Member Descriptions|
kstat Member |
Description |
ks_crtime |
Time at which the kstat was created, commonly used in calculating rates of various counters. |
ks_next |
Points to next kstat in chain. |
ks_kid |
Unique ID for kstat, for example,??? |
ks_module[KSTAT_STRLEN] |
Identifies kernel module that created kstat. ks_module is combined with ks_instance and ks_name to give the kstat a unique, meaningful name. KSTAT_STRLEN sets the maximum length of ks_module. |
ks_resv |
A reserved field. |
ks_instance |
The instance of the kernel module that created this kstat. ks_instance is combined with ks_module and ks_name to give the kstat a unique, meaningful name. |
ks_name[KSTAT_STRLEN] |
A name assigned to the kstat in combination with ks_module and ks_instance. KSTAT_STRLEN sets the maximum length of ks_module. |
ks_type |
The data type,which can be KSTAT_TYPE_RAW (binary data), KSTAT_TYPE_NAMED (name/value pairs), KSTAT_TYPE_INTR (interrupt statistics), KSTAT_TYPE_IO (I/O statistics), and KSTAT_TYPE_TIMER (event timers). |
ks_class[KSTAT_STRLEN] |
This categorizes the kstat into one of the following classes: bus, controller, device_error, disk, hat, kmem_cache, kstat, misc, net, nfs, pages, partition, rps, ufs, vm, and vmem. |
ks_data |
Points to the data saction for the kstat. |
ks_ndata |
Indicates the number of data records, for those kstat types that support multiple records (KSTAT_TYPE_RAW, KSTAT_TYPE_NAMED, and KSTAT_TYPE_TIMER). |
ks_data_size |
Total size of the data section in bytes. |
ks_snaptime |
The timestamp for the last data sanpshot, useful in calculating rates. |
