SCSA defines a global variable, scsi_options, which can be used for debug and control. The defined bits in scsi_options can be found in the file <sys/scsi/conf/autoconf.h>. The following table describes the use of these bits.
Table 14–2 SCSA Options
Option |
Description |
SCSI_OPTIONS_DR |
Enables global disconnect/reconnect |
SCSI_OPTIONS_SYNC |
Enables global synchronous transfer capability |
SCSI_OPTIONS_LINK |
Enables global link support |
SCSI_OPTIONS_PARITY |
Enables global parity support |
SCSI_OPTIONS_TAG |
Enables global tagged queuing support |
SCSI_OPTIONS_FAST |
Enables global FAST SCSI support: 10 Mbytes/sec transfers, as opposed to 5 Mbytes/sec |
SCSI_OPTIONS_FAST20 |
Enables global FAST20 SCSI support: 20 Mbytes/sec transfers |
SCSI_OPTIONS_FAST40 |
Enables global FAST40 SCSI support: 40 Mbytes/sec transfers |
SCSI_OPTIONS_FAST80 |
Enables global FAST80 SCSI support: 80 Mbytes/sec transfers |
SCSI_OPTIONS_WIDE |
Enables global WIDE SCSI |
The setting of scsi_options affects all host adapter and target drivers present on the system (as opposed to scsi_ifsetcap(9F). Refer to the scsi_hba_attach(9F) man page for information on controlling these options for a particular host adapter.
