The scsi_init_pkt(9F) routine allocates and zeros a scsi_pkt(9S) structure; it also sets pointers to pkt_private, *pkt_scbp, and *pkt_cdbp. Additionally, it provides a callback mechanism to handle the case where resources are not available. This function has the following syntax:
struct scsi_pkt *scsi_init_pkt(struct scsi_address *ap,
struct scsi_pkt *pktp, struct buf *bp, int cmdlen,
int statuslen, int privatelen, int flags,
int (*callback)(caddr_t), caddr_t arg)
Pointer to a scsi_address structure. This is the sd_address field of the device's scsi_device(9S) structure.
Pointer to the scsi_pkt(9S) structure to be initialized. If this is set to NULL, a new packet is allocated.
Pointer to a buf(9S) structure. If this is non-NULL and contains a valid byte count, DMA resources are allocated.
Length of the SCSI command descriptor block in bytes.
Required length of the SCSI status completion block in bytes.
Number of bytes to allocate for the pkt_private field.
Set of flags. Possible bits include:
PKT_CONSISTENT – This bit must be set if the DMA buffer was allocated using scsi_alloc_consistent_buf(9F). In this case, the host bus adapter driver guarantees that the data transfer is properly synchronized before performing the target driver's command completion callback.
PKT_DMA_PARTIAL – This bit can be set if the driver accepts a partial DMA mapping. If set, scsi_init_pkt(9F) allocates DMA resources with the DDI_DMA_PARTIAL flag set. The pkt_resid field of the scsi_pkt(9S) structure can be returned with a nonzero residual, indicating the number of bytes for which scsi_init_pkt(9F) was unable to allocate DMA resources.
Specifies the action to take if resources are not available. If set to NULL_FUNC, scsi_init_pkt(9F) returns immediately (returning NULL). If set to SLEEP_FUNC, it does not return until resources are available. Any other valid kernel address is interpreted as the address of a function to be called when resources are likely to be available.
Parameter to pass to the callback function.
The scsi_init_pkt() routine synchronizes the data prior to transport. If the driver needs to access the data after transport, it should call scsi_sync_pkt(9F) to flush any intermediate caches. The scsi_sync_pkt() routine can be used to synchronize any cached data.
