The detach(9E) entry point is the inverse of attach(9E); it must free all resources that were allocated in attach(). If successful, the detach should call scsi_unprobe(9F). Example 14–3 shows a target driver detach() routine.
static int
xxdetach(dev_info_t *dip, ddi_detach_cmd_t cmd)
struct xxstate *xsp;
switch (cmd) {
case DDI_DETACH:
normal detach(9E) operations, such as getting a
pointer to the state structure
scsi_free_consistent_buf(xsp->rqsbuf);
scsi_destroy_pkt(xsp->rqs);
xsp->sdp->sd_private = (caddr_t)NULL;
xsp->sdp->sd_sense = NULL;
scsi_unprobe(xsp->sdp);
remove minor nodes
free resources, such as the state structure and properties
return (DDI_SUCCESS);
case DDI_SUSPEND:
For information, see Chapter 9
default:
return (DDI_FAILURE);
