If the host bus adapter hardware supports power management, and the host bus adapter only needs to be powered down when all of the target adapters are power manageable and are at power level 0, then the host bus adapter driver only needs to provide a power(9E) entry point as described in Chapter 9, Power Management and create a pm-components(9P) property that describes the components that the device implements.
Nothing more is necessary, since the components will default to idle, and the power management framework's default dependency processing will ensure that the host bus adapter will be powered up whenever an target adapter is powered up and will automatically power down the host bus adapter whenever all of the target adapters are powered down (provided that automatic power management is enabled).
