SCSA defines a number of HBA driver entry points, listed in the following table. These entry points are called by the system when configuring a target driver instance connected to the HBA driver, or when the target driver makes a SCSA request. See SCSA HBA Entry Points for more information.
Table 15–1 SCSA HBA Entry Point Summary|
Function Name |
Called as a Result of |
tran_tgt_init(9E) |
System attaching target device instance |
tran_tgt_probe(9E) |
Target driver calling scsi_probe(9F) |
tran_tgt_free(9E) |
System detaching target device instance |
tran_start(9E) |
Target driver calling scsi_transport(9F) |
tran_reset(9E) |
Target driver calling scsi_reset(9F) |
tran_abort(9E) |
Target driver calling scsi_abort(9F) |
tran_getcap(9E) |
Target driver calling scsi_ifgetcap(9F) |
tran_setcap(9E) |
Target driver calling scsi_ifsetcap(9F) |
tran_init_pkt(9E) |
Target driver calling scsi_init_pkt(9F) |
tran_destroy_pkt(9E) |
Target driver calling scsi_destroy_pkt(9F) |
tran_dmafree(9E) |
Target driver calling scsi_dmafree(9F) |
tran_sync_pkt(9E) |
Target driver calling scsi_sync_pkt(9F) |
(9E)tran_reset_notify |
Target driver calling scsi_reset_notify(9F) |
tran_quiesce(9E) |
System quiescing bus |
tran_unquiesce(9E) |
System resuming activity on bus |
tran_bus_reset(9E) |
System resetting bus |
