Writing Device Drivers
scsi_pkt Structure
To execute SCSI commands, a target driver must first allocate a scsi_pkt(9S) structure for the command, specifying its own private data area length, the command status, and the command length. The HBA driver is responsible for implementing the packet allocation in the tran_init_pkt(9E) entry point. The HBA driver is also responsible for freeing the packet in its tran_destroy_pkt(9E) entry point. See scsi_pkt(9S) in Chapter 14, SCSI Target Drivers, for more information.
The scsi_pkt(9S) structure contains these fields:
struct scsi_pkt {
    opaque_t pkt_ha_private;         /* private data for host adapter */
    struct scsi_address pkt_address; /* destination address */
    opaque_t pkt_private;            /* private data for target driver */
    void    (*pkt_comp)(struct scsi_pkt *); /* completion routine */
    uint_t  pkt_flags;               /* flags */
    int     pkt_time;                /* time allotted to complete command */
    uchar_t *pkt_scbp;               /* pointer to status block */
    uchar_t *pkt_cdbp;               /* pointer to command block */
    ssize_t pkt_resid;               /* data bytes not transferred */
    uint_t  pkt_state;               /* state of command */
    uint_t  pkt_statistics;          /* statistics */
    uchar_t pkt_reason;              /* reason completion called */
pkt_ha_private
Pointer to per-command HBA-driver private data.
pkt_address
Pointer to the scsi_address(9S) structure providing address information for this command.
pkt_private
Pointer to per-packet target-driver private data.
pkt_comp
Pointer to the target driver completion routine called by the HBA driver when the transport layer has completed this command.
pkt_flags
Flags for the command.
pkt_time
Specifies the completion timeout in seconds for the command.
pkt_scbp
Pointer to the status completion block for the command.
pkt_cdbp
Pointer to the command descriptor block (CDB) for the command.
pkt_resid
Count of the data bytes not transferred when the command has been completed or the amount of data for which resources have not been allocated. The HBA must modify this field during transport.
pkt_state
State of the command. The HBA must modify this field during transport.
pkt_statistics
Provides a history of the events the command experienced while in the transport layer. The HBA must modify this field during transport.
pkt_reason
Reason for command completion. The HBA must modify this field during transport.
