The tran_tgt_probe(9E) entry point enables the HBA to customize the operation of scsi_probe(9F), if necessary. This entry point is called only when the target driver calls scsi_probe(9F).
The HBA driver can retain the normal operation of scsi_probe(9F) by calling scsi_hba_probe(9F) and returning its return value.
This entry point is not required, and if not needed, the HBA driver should set the tran_tgt_probe vector in the scsi_hba_tran(9S) structure to point to scsi_hba_probe(9F).
scsi_probe(9F) allocates a scsi_inquiry(9S) structure and sets the sd_inq field of the scsi_device(9S) structure to point to the data in scsi_inquiry(9S). scsi_hba_probe(9F) handles this automatically. scsi_unprobe(9F) then frees the scsi_inquiry(9S) data.
Other than during the allocation of scsi_inquiry(9S) data, normally handled by scsi_hba_probe(9F), tran_tgt_probe(9E) must be stateless, as the same SCSI device might call it multiple times.
The allocation of the scsi_inquiry(9S) structure is handled automatically by scsi_hba_probe(9F). This is only of concern if you want custom scsi_probe(9F) handling.
static int
isp_tran_tgt_probe(
struct scsi_device *sd,
int (*callback)())
Perform any special probe customization needed.
* Normal probe handling
return (scsi_hba_probe(sd, callback));
