For a previously allocated packet with data remaining to be transferred, the tran_init_pkt(9E) entry point must reallocate DMA resources when the following conditions apply:
Partial DMA resources have already been allocated.
A non-zero pkt_resid was returned in the previous call to tran_init_pkt(9E).
bp is not NULL.
bp->b_bcount is not zero.
When reallocating DMA resources to the next portion of the transfer, tran_init_pkt(9E) must return the amount of DMA resources not allocated for this transfer in the field pkt_resid.
If an error occurs while attempting to move DMA resources, tran_init_pkt(9E) must not free the scsi_pkt(9S). The target driver in this case is responsible for freeing the pkt.
If the callback parameter is NULL_FUNC, the tran_init_pkt(9E) entry point must not sleep or call any function that might sleep. If the callback parameter is SLEEP_FUNC and resources are not immediately available, the tran_init_pkt(9E) entry point should sleep until resources are available, unless the request is impossible to satisfy.
static int
isp_i_dma_move(
struct isp *isp,
struct scsi_pkt *pkt,
struct buf *bp)
struct isp_cmd *sp = (struct isp_cmd *)pkt->pkt_ha_private;
int i;
ASSERT(sp->cmd_flags & CFLAG_COMPLETED);
sp->cmd_flags &= ~CFLAG_COMPLETED;
* If there are no more cookies remaining in this window,
* must move to the next window first.
if (sp->cmd_cookie == sp->cmd_ncookies) {
* For small pkts, leave things where they are
if (sp->cmd_curwin == sp->cmd_nwin && sp->cmd_nwin == 1)
return (1);
* At last window, cannot move
if (++sp->cmd_curwin >= sp->cmd_nwin)
return (0);
if (ddi_dma_getwin(sp->cmd_dmahandle, sp->cmd_curwin,
&sp->cmd_dma_offset, &sp->cmd_dma_len,
&sp->cmd_dmacookies[0], &sp->cmd_ncookies) ==
DDI_FAILURE)
return (0);
sp->cmd_cookie = 0;
} else {
* Still more cookies in this window - get the next one
ddi_dma_nextcookie(sp->cmd_dmahandle,
&sp->cmd_dmacookies[0]);
* Get remaining cookies in this window, up to our maximum
i = 0;
for (;;) {
sp->cmd_dmacount += sp->cmd_dmacookies[i++].dmac_size;
sp->cmd_cookie++;
if (i == ISP_NDATASEGS ||
break;
&sp->cmd_dmacookies[i]);
sp->cmd_cookiecnt = i;
pkt->pkt_resid = bp->b_bcount - sp->cmd_dmacount;
return (1);
