Writing Device Drivers
SCSI HBA Driver Specific Issues
The section covers issues specific to SCSI HBA drivers.
Installing HBA Drivers
A SCSI HBA driver is installed like a leaf driver (see Chapter 17, Compiling, Loading, Packaging, and Testing Drivers), except that the add_drv(1M) command must specify the driver class as SCSI, such as:
# add_drv -m" * 0666 root root" -i'"pci1077,1020"' -c scsi isp
HBA Configuration Properties
When attaching an instance of an HBA device, scsi_hba_attach_setup(9F) creates a number of SCSI configuration parameter properties for that HBA instance. A particular property is created only if there is no existing property of the same name already attached to the HBA instance, permitting a default property value to be overridden in an HBA configuration file.
An HBA driver must use ddi_prop_get_int(9F) to retrieve each property. The HBA driver then modifies (or accepts the default value of) the properties to configure its specific operation.
scsi-reset-delay Property
The scsi-reset-delay property is an integer specifying the SCSI bus or device reset delay recovery time in milliseconds.
scsi-options Property
The scsi-options property is an integer specifying a number of options through individually defined bits. The bits in scsi_options are:
Per-target scsi-options
An HBA driver might support a per-target scsi-options feature in the following format:
    target<n>-scsi-options=<hex value>
In this example, < n> is the target ID. If the per-target scsi-options property is defined for a particular target, the HBA driver uses the value of the per-target scsi-options property for that target rather than the per-HBA driver instance scsi-options property. This can provide more precise control if, for example, synchronous data transfer needs to be disabled for just one particular target device. The per-target scsi-options property can be defined in the driver.conf(4) file.
Here is an example of a per-target scsi-options property definition to disable synchronous data transfer for target device 3:
    target3-scsi-options=0x2d8
IA Target Driver Configuration Properties
Some IA SCSI target drivers (such as the cmdk disk target driver) use the following configuration properties:
When using the cmdk sample driver to write an HBA driver for an IA platform, one or more of these properties (as appropriate to the HBA driver and hardware) need to be defined in the driver.conf(4) file.
Note –
These property definitions should appear only in an HBA driver's driver.conf(4) file. The HBA driver itself should not inspect or attempt to interpret these properties in any way. These properties are advisory only and serve as an adjunct to the cmdk driver. They should not be relied upon in any way. The property definitions might or might not be used in future releases.
The disk property can be used to define the type of disk supported by cmdk. For a SCSI HBA, the only possible value for the disk property is:
The queue property defines how the disk driver sorts the queue of incoming requests during strategy(9E). There are two possible values:
The flow_control property defines how commands are transported to the HBA driver. There are three possible values:
Here is an example of a driver.conf(4) file for use with an IA HBA PCI device designed for use with the cmdk sample driver:
# config file for ISP 1020 SCSI HBA driver
       flow_control="dsngl" queue="qsort" disk="scdk"
       scsi-initiator-id=7;
