Some IA SCSI target drivers (such as the cmdk disk target driver) use the following configuration properties:
disk
queue
flow_control
When using the cmdk sample driver to write an HBA driver for an IA platform, one or more of these properties (as appropriate to the HBA driver and hardware) need to be defined in the driver.conf(4) file.
These property definitions should appear only in an HBA driver's driver.conf(4) file. The HBA driver itself should not inspect or attempt to interpret these properties in any way. These properties are advisory only and serve as an adjunct to the cmdk driver. They should not be relied upon in any way. The property definitions might or might not be used in future releases.
The disk property can be used to define the type of disk supported by cmdk. For a SCSI HBA, the only possible value for the disk property is:
disk="scdk" – Disk type is a SCSI disk
The queue property defines how the disk driver sorts the queue of incoming requests during strategy(9E). There are two possible values:
queue="qsort" – One-way elevator queuing model, provided by disksort(9F)
queue="qfifo" – FIFO (first in, first out) queuing model
The flow_control property defines how commands are transported to the HBA driver. There are three possible values:
flow_control="dsngl" – Single command per HBA driver
flow_control="dmult" – Multiple commands per HBA driver—when the HBA queue is full, the driver returns TRAN_BUSY
flow_control="duplx" – The HBA can support separate read and write queues, with multiple commands per queue. FIFO ordering is used for the write queue; the queuing model used for the read queue is described by the queue property. When an HBA queue is full, the driver returns TRAN_BUSY
Here is an example of a driver.conf(4) file for use with an IA HBA PCI device designed for use with the cmdk sample driver:
# config file for ISP 1020 SCSI HBA driver
flow_control="dsngl" queue="qsort" disk="scdk"
scsi-initiator-id=7;
