Writing Device Drivers
SCSA HBA Interfaces
SCSA HBA interfaces include HBA entry points, HBA data structures, and an HBA framework.
SCSA HBA Entry Point Summary
SCSA defines a number of HBA driver entry points, listed in the following table. These entry points are called by the system when configuring a target driver instance connected to the HBA driver, or when the target driver makes a SCSA request. See SCSA HBA Entry Points for more information.
Table 15–1 SCSA HBA Entry Point Summary
Function Name
Called as a Result of
tran_tgt_init(9E)
System attaching target device instance
tran_tgt_probe(9E)
Target driver calling scsi_probe(9F)
tran_tgt_free(9E)
System detaching target device instance
tran_start(9E)
Target driver calling scsi_transport(9F)
tran_reset(9E)
Target driver calling scsi_reset(9F)
tran_abort(9E)
Target driver calling scsi_abort(9F)
tran_getcap(9E)
Target driver calling scsi_ifgetcap(9F)
tran_setcap(9E)
Target driver calling scsi_ifsetcap(9F)
tran_init_pkt(9E)
Target driver calling scsi_init_pkt(9F)
tran_destroy_pkt(9E)
Target driver calling scsi_destroy_pkt(9F)
tran_dmafree(9E)
Target driver calling scsi_dmafree(9F)
tran_sync_pkt(9E)
Target driver calling scsi_sync_pkt(9F)
(9E)tran_reset_notify
Target driver calling scsi_reset_notify(9F)
tran_quiesce(9E)
System quiescing bus
tran_unquiesce(9E)
System resuming activity on bus
tran_bus_reset(9E)
System resetting bus
SCSA HBA Data Structures
SCSA defines data structures to enable the exchange of information between the target and HBA drivers. These data structures include:
scsi_hba_tran(9S) Structure
Each instance of an HBA driver must allocate a scsi_hba_tran(9S) structure using scsi_hba_tran_alloc(9F) in the attach(9E) entry point. scsi_hba_tran_alloc(9F) initializes the scsi_hba_tran(9S) structure before it returns. The HBA driver must initialize specific vectors in the transport structure to point to entry points within the HBA driver. Once initialized, the HBA driver exports the transport structure to SCSA by calling scsi_hba_attach_setup(9F).
Caution – Caution –
Because SCSA keeps a pointer to the transport structure in the driver-private field on the devinfo node, HBA drivers must not use ddi_set_driver_private(9F). They can, however, use ddi_get_driver_private(9F) to retrieve the pointer to the transport structure.
The scsi_hba_tran(9S) structure contains the following fields:
struct scsi_hba_tran {
        dev_info_t      *tran_hba_dip;
        void            *tran_hba_private;      /* HBA softstate */
        void            *tran_tgt_private;      /* target-specific info */
        struct scsi_device      *tran_sd;
        int             (*tran_tgt_init)();
        int             (*tran_tgt_probe)();
        void            (*tran_tgt_free)();
        int             (*tran_start)();
        int             (*tran_reset)();
        int             (*tran_abort)();
        int             (*tran_getcap)();
        int             (*tran_setcap)();
        struct scsi_pkt *(*tran_init_pkt)();
        void            (*tran_destroy_pkt)();
        void            (*tran_dmafree)();
        void            (*tran_sync_pkt)();
        int             (*tran_reset_notify)();
        int             (*tran_quiesce)();
        int             (*tran_unquiesce)();
        int             (*tran_bus_reset)();
Note –
Code fragments presented subsequently in this chapter use these fields to describe practical HBA driver operations. See SCSA HBA Entry Points for more information.
where:
tran_hba_dip
Pointer to the HBA device instance dev_info structure. The function scsi_hba_attach_setup(9F) sets this field.
tran_hba_private
Pointer to private data maintained by the HBA driver. Usually, tran_hba_private contains a pointer to the state structure of the HBA driver.
tran_tgt_private
Pointer to private data maintained by the HBA driver when using cloning. By specifying SCSI_HBA_TRAN_CLONE when calling scsi_hba_attach_setup(9F), the scsi_hba_tran(9S) structure is cloned once per target, permitting the HBA to initialize this field to point to a per-target instance data structure in the tran_tgt_init(9E) entry point. If SCSI_HBA_TRAN_CLONE is not specified, tran_tgt_private is NULL and must not be referenced. See Transport Structure Cloning for more information.
tran_sd
Pointer to a per-target instance scsi_device(9S) structure used when cloning. If SCSI_HBA_TRAN_CLONE is passed to scsi_hba_attach_setup(9F), tran_sd is initialized to point to the per-target scsi_device structure before any HBA functions are called on behalf of that target. If SCSI_HBA_TRAN_CLONE is not specified, tran_sd is NULL and must not be referenced. See Transport Structure Cloning for more information.
tran_tgt_init
Pointer to the HBA driver entry point called when initializing a target device instance. If no per-target initialization is required, the HBA can leave tran_tgt_init set to NULL.
tran_tgt_probe
Pointer to the HBA driver entry point called when a target driver instance calls scsi_probe(9F) to probe for the existence of a target device. If no target probing customization is required for this HBA, the HBA should set tran_tgt_probe to scsi_hba_probe(9F).
tran_tgt_free
Pointer to the HBA driver entry point called when a target device instance is destroyed. If no per-target deallocation is necessary, the HBA can leave tran_tgt_free set to NULL.
tran_start
Pointer to the HBA driver entry point called when a target driver calls scsi_transport(9F).
tran_reset
Pointer to the HBA driver entry point called when a target driver calls scsi_reset(9F).
tran_abort
Pointer to the HBA driver entry point called when a target driver calls scsi_abort(9F).
tran_getcap
Pointer to the HBA driver entry point called when a target driver calls scsi_ifgetcap(9F).
tran_setcap
Pointer to the HBA driver entry point called when a target driver calls scsi_ifsetcap(9F).
tran_init_pkt
Pointer to the HBA driver entry point called when a target driver calls scsi_init_pkt(9F).
tran_destroy_pkt
Pointer to the HBA driver entry point called when a target driver calls scsi_destroy_pkt(9F).
tran_dmafree
Pointer to the HBA driver entry point called when a target driver calls scsi_dmafree(9F).
tran_sync_pkt
Pointer to the HBA driver entry point called when a target driver calls scsi_sync_pkt(9F).
tran_reset_notify
Pointer to the HBA driver entry point called when a target driver calls tran_reset_notify(9E).
scsi_address Structure
The scsi_address(9S) structure provides transport and addressing information for each SCSI command allocated and transported by a target driver instance.
The scsi_address structure contains the following fields:
struct scsi_address {
        struct scsi_hba_tran    *a_hba_tran;    /* Transport vectors */
        ushort_t                a_target;       /* Target identifier */
        uchar_t                 a_lun;          /* Lun on that Target */
        uchar_t                 a_sublun;       /* Sublun on that Lun */
                                                /* Not used */
a_hba_tran
Pointer to the scsi_hba_tran(9S) structure, as allocated and initialized by the HBA driver. If SCSI_HBA_TRAN_CLONE was specified as the flag to scsi_hba_attach_setup(9F), a_hba_tran points to a copy of that structure.
a_target
Identifies the SCSI target on the SCSI bus.
a_lun
Identifies the SCSI logical unit on the SCSI target.
scsi_device Structure
The HBA framework allocates and initializes a scsi_device(9S) structure for each instance of a target device before calling an HBA driver's tran_tgt_init(9E) entry point. This structure stores information about each SCSI logical unit, including pointers to information areas that contain both generic and device-specific information. There is one scsi_device(9S) structure for each target device instance attached to the system.
If the per-target initialization is successful (in other words, if either tran_tgt_init(9E) returns success or the vector is NULL), the HBA framework will set the target driver's per-instance private data to point to the scsi_device(9S) structure, using ddi_set_driver_private(9F).
The scsi_device(9S) structure contains the following fields:
struct scsi_device {
    struct scsi_address          sd_address;    /* routing information */
    dev_info_t                   *sd_dev;       /* device dev_info node */
    kmutex_t                     sd_mutex;      /* mutex used by device */
    void                         *sd_reserved;
    struct scsi_inquiry          *sd_inq;
    struct scsi_extended_sense   *sd_sense;
    caddr_t                      sd_private;    /* for driver's use */
sd_address
Data structure that is passed to the SCSI resource allocation routines.
sd_dev
Pointer to the target's dev_info structure.
sd_mutex
Mutex for use by the target driver. This is initialized by the HBA framework and can be used by the target driver as a per-device mutex. This mutex should not be held across a call to scsi_transport(9F) or scsi_poll(9F). See Chapter 3, Multithreading for more information on mutexes.
sd_inq
Pointer for the target device's SCSI inquiry data. The scsi_probe(9F) routine allocates a buffer, fills it in, and attaches it to this field.
sd_sense
Pointer to a buffer to contain Request Sense data from the device. The target driver must allocate and manage this buffer itself. See the target driver's attach(9E) routine in The attach() Entry Point for more information.
sd_private
Pointer field for use by the target driver. It is commonly used to store a pointer to a private target driver state structure.
scsi_pkt Structure
To execute SCSI commands, a target driver must first allocate a scsi_pkt(9S) structure for the command, specifying its own private data area length, the command status, and the command length. The HBA driver is responsible for implementing the packet allocation in the tran_init_pkt(9E) entry point. The HBA driver is also responsible for freeing the packet in its tran_destroy_pkt(9E) entry point. See scsi_pkt(9S) in Chapter 14, SCSI Target Drivers, for more information.
The scsi_pkt(9S) structure contains these fields:
struct scsi_pkt {
    opaque_t pkt_ha_private;         /* private data for host adapter */
    struct scsi_address pkt_address; /* destination address */
    opaque_t pkt_private;            /* private data for target driver */
    void    (*pkt_comp)(struct scsi_pkt *); /* completion routine */
    uint_t  pkt_flags;               /* flags */
    int     pkt_time;                /* time allotted to complete command */
    uchar_t *pkt_scbp;               /* pointer to status block */
    uchar_t *pkt_cdbp;               /* pointer to command block */
    ssize_t pkt_resid;               /* data bytes not transferred */
    uint_t  pkt_state;               /* state of command */
    uint_t  pkt_statistics;          /* statistics */
    uchar_t pkt_reason;              /* reason completion called */
pkt_ha_private
Pointer to per-command HBA-driver private data.
pkt_address
Pointer to the scsi_address(9S) structure providing address information for this command.
pkt_private
Pointer to per-packet target-driver private data.
pkt_comp
Pointer to the target driver completion routine called by the HBA driver when the transport layer has completed this command.
pkt_flags
Flags for the command.
pkt_time
Specifies the completion timeout in seconds for the command.
pkt_scbp
Pointer to the status completion block for the command.
pkt_cdbp
Pointer to the command descriptor block (CDB) for the command.
pkt_resid
Count of the data bytes not transferred when the command has been completed or the amount of data for which resources have not been allocated. The HBA must modify this field during transport.
pkt_state
State of the command. The HBA must modify this field during transport.
pkt_statistics
Provides a history of the events the command experienced while in the transport layer. The HBA must modify this field during transport.
pkt_reason
Reason for command completion. The HBA must modify this field during transport.
Per-Target Instance Data
An HBA driver must allocate a scsi_hba_tran(9S) structure during attach(9E) and initialize the vectors in this transport structure to point to the required HBA driver entry points. This scsi_hba_tran(9S) structure is then passed into scsi_hba_attach_setup(9F).
The scsi_hba_tran(9S) structure contains a tran_hba_private field, which can be used to refer to the HBA driver's per-instance state.
Each scsi_address(9S) structure contains a pointer to the scsi_hba_tran(9S) structure and also provides the target (a_target) and logical unit (a_lun) addresses for the particular target device. Because every HBA driver entry point is passed a pointer to the scsi_address(9S) structure, either directly or indirectly through the scsi_device(9S) structure, the HBA driver can reference its own state and can identify the target device being addressed.
The following figure illustrates the HBA data structures for transport operations.
Figure 15–3 HBA Transport Structures
Diagram shows the relationships of structures involved in the HBA transport layer.
Cloning can be useful if an HBA driver needs to maintain per-target private data in the scsi_hba_tran(9S) structure, or if it needs to maintain a more complex address than is provided in the scsi_address(9S) structure.
When cloning, the HBA driver must still allocate a scsi_hba_tran structure at attach(9E) time and initialize the tran_hba_private soft state pointer and HBA entry point vectors as before. The difference occurs when the framework begins to connect an instance of a target driver to the HBA driver. Before calling the HBA driver's tran_tgt_init(9E) entry point, the framework duplicates (clones) thescsi_hba_tran structure associated with that instance of the HBA. This means that each scsi_address(9S) structure, allocated and initialized for a particular target device instance, points to a per-target instance copy of the scsi_hba_tran structure, not to the scsi_hba_tran structure allocated by the HBA driver at attach(9E) time.
Two important pointers that an HBA driver can use when it has specified cloning are contained in the scsi_hba_tran structure. The first pointer is the tran_tgt_private field, which the driver can use to point to per-target HBA private data. This is useful, for example, if an HBA driver needs to maintain a more complex address than the a_target and a_lun fields in the scsi_address(9S) structure allow. The second pointer is the tran_sd field, which is a pointer to the scsi_device(9S) structure referring to the particular target device.
When specifying cloning, the HBA driver must allocate and initialize the per-target data and initialize the tran_tgt_private field to point to this data during its tran_tgt_init(9E) entry point. The HBA driver must free this per-target data during its tran_tgt_free(9E) entry point.
When cloning, the framework initializes the tran_sd field to point to the scsi_device(9S) structure before the HBA driver tran_tgt_init(9E) entry point is called. The driver requests cloning by passing the SCSI_HBA_TRAN_CLONE flag to scsi_hba_attach_setup(9F). Figure 15–4 illustrates the HBA data structures for cloning transport operations.
Figure 15–4 Cloning Transport Operation
Diagram shows an example of cloned HBA structures.
SCSA HBA Functions
SCSA also provides a number of functions, listed in Table 15–2, for use by HBA drivers.
Table 15–2 SCSA HBA Functions
Function Name
Called by Driver Entry Point
scsi_hba_init(9F)
_init(9E)
scsi_hba_fini(9F)
_fini(9E)
attach(9E)
scsi_hba_detach(9F)
detach(9E)
attach(9E)
scsi_hba_tran_free(9F)
detach(9E)
scsi_hba_probe(9F)
tran_tgt_probe(9E)
scsi_hba_pkt_alloc(9F)
tran_init_pkt(9E)
scsi_hba_pkt_free(9F)
scsi_hba_lookup_capstr(9F)
tran_getcap(9E) and tran_setcap(9E)
