voidgld_recv(gld_mac_info_t *macinfo,mblk_t *mp);
gld_recv() is called by the driver's interrupt handler to pass a received packet upstream. The driver must construct and pass a STREAMS M_DATA message containing the raw packet. gld_recv() determines which STREAMS queues, if any, should receive a copy of the packet, duplicating it if necessary. It then formats a DL_UNITDATA_IND message, if required, and passes the data up all appropriate Streams.
The driver should avoid holding mutex or other locks during the call to gld_recv(). In particular, locks that could be taken by a transmit thread must not be held during a call to gld_recv(): the interrupt thread that calls gld_recv() will in some cases carry out processing that includes sending an outgoing packet, resulting in a call to the driver's gldm_send() routine. If the gldm_send() routine were to try to acquire a mutex being held by the gldm_intr() routine at the time it calls gld_recv(), this would result in a panic caused by a recursive mutex entry. If other driver entry points attempt to acquire a mutex that the driver holds across a call to gld_recv(), deadlock can result.
