The PROM provides a variety of 8-bit, 16-bit, and 32-bit operations. In general, a c (character) prefix indicates an 8-bit (one byte) operation; a w (word) prefix indicates a 16-bit (two byte) operation; and an L (longword) prefix indicates a 32-bit (four byte) operation.
A suffix of ! indicates a write operation. The write operation takes the first two items off the stack; the first item is the address, and the second item is the value.
ok 55 ffe98000 c!
A suffix of @ indicates a read operation. The read operation takes one argument (the address) off the stack.
ok ffe98000 c@ ok .s 55
A suffix of ? is used to display the value, without affecting the stack.
ok ffe98000 c? 55
Be careful when trying to query the device. If the mappings are not set up correctly, trying to read or write could cause errors. Special words are provided to handle these cases. cprobe, wprobe, and lprobe, for example, read from the given address but return zero if the location does not respond, or nonzero if it does.
ok fffa4000 c@ Data Access Error ok fffa4000 cprobe ok .s0 ok ffe98000 cprobe ok .s 0 ffffffffffffffff
A region of memory can be shown with the dump word. This takes an address and a length, and displays the contents of the memory region in bytes.
In the following example, the fill word is used to fill video memory with a pattern. fill takes the address, the number of bytes to fill, and the byte to use (there is also a wfill and an Lfill for words and longwords). This causes the cgsix to display simple patterns based on the byte passed.
ok “ /sbus” select-dev ok 800000 2 100000 map-in ok constant fb ok fb 10000 ff fill ok fb 20000 0 fill ok fb 18000 55 fill ok fb 15000 3 fill ok fb 10000 5 fillok fb 5000 f9 fill
