# metainit hsp001 c2t2d0s2 c3t2d0s2 hsp001: Hotspare pool is setup |
In this example, the hot spare pool hsp001 contains two disks as the hot spares. The system confirms that the hot spare pool has been set up.
Solaris Volume Manager will not warn you if you create a hot spare that is not large enough. If the hot spare is not equal to, or larger than, the volume to which it is attached, the hot spare will not work.
