# metainit -f d12 1 1 c0t3d0s6 d12: Concat/Stripe is setup # metainit d22 1 1 c1t0d0s6 d22: Concat/Stripe is setup # metainit d2 -m d12 d2: Mirror is setup (Edit the /etc/vfstab file so that /usr references the mirror) # reboot ... # metattach d2 d22 d2: Submirror d22 is attached |
The -f option forces the creation of the first concatenation, d12, which contains the mounted file system /usr on /dev/dsk/c0t3d0s6. The second concatenation, d22, is created from /dev/dsk/c1t0d0s6. (This slice must be the same size or greater than that of d12.) The metainit command with the -m option creates the one-way mirror d2 using the concatenation containing /usr. Next, the /etc/vfstab file must be edited to change the entry for /usr to reference the mirror. For example, the following line:
/dev/dsk/c0t3d0s6 /dev/rdsk/c0t3d0s6 /usr ufs 1 yes - |
should be changed to:
/dev/md/dsk/d2 /dev/md/rdsk/d2 /usr ufs 1 yes - |
After a reboot, the second submirror d22 is attached to the mirror, causing a mirror resynchronization. (The system confirms that the concatenation and the mirror are set up, and that submirror d22 is attached.
