# metastat d5 d5: Trans State: Hard Error Size: 10080 blocks Master Device: d4 Logging Device: c0t0d0s6 d4: Mirror State: Okay ... c0t0d0s6: Logging device for d5 State: Hard Error Size: 5350 blocks ... # fsck /dev/md/rdsk/d5 ** /dev/md/rdsk/d5 ** Last Mounted on /fs1 ** Phase 1 - Check Blocks and Sizes ** Phase 2 - Check Pathnames ** Phase 3 - Check Connectivity ** Phase 4 - Check Reference Counts ** Phase 5 - Check Cyl groups WARNING: md: log device: /dev/dsk/c0t0d0s6 changed state to Okay 4 files, 11 used, 4452 free (20 frags, 554 blocks, 0.4% fragmentation) # metastat d5 d5: Trans State: Okay Size: 10080 blocks Master Device: d4 Logging Device: c0t0d0s6 d4: Mirror State: Okay ... c0t0d0s6: Logging device for d5 State: Okay ... |
This example shows a transactional volume, d5, which has a log device in the “Hard Error” state, being fixed. You must run the fsck command on the transactional volume itself, which transitions the state of the transactional volume to “Okay.” The metastat command confirms that the state is “Okay.”
