# metareplace -e d20 c2t0d0s2 |
In this example, the RAID 5 volume d20 has a slice, c2t0d0s2, which had a soft error. The metareplace command with the -e option enables the slice.
If a disk drive is defective, you can either replace it with another available disk (and its slices) on the system as documented in How to Replace a Component in a RAID 5 Volume. Alternatively, you can repair/replace the disk, label it, and run the metareplace command with the -e option.
