Solaris Volume Manager Administration Guide
Solaris Volume Manager Roadmap—Availability
Table 1–2 Solaris Volume Manager Roadmap—Availablity
Task
Description
For Instructions
Maximize data availability
Use Solaris Volume Manager's mirroring feature to maintain multiple copies of your data. You can create a RAID 1 volume from unused slices in preparation for data, or you can mirror an existing file system, including root (/) and /usr.
How to Create a RAID 1 Volume From Unused Slices
How to Create a RAID 1 Volume From a File System
Add data availability with minimum hardware cost
Increase data availability with minimum of hardware by using Solaris Volume Manager's RAID 5 volumes.
How to Create a RAID 5 Volume
Increase data availability for an existing RAID 1 or RAID 5 volume
Increase data availability for a RAID 1 or a RAID 5 volume, by creating a hot spare pool then associate it with a mirror's submirrors, or a RAID 5 volume.
Creating a Hot Spare Pool
Associating a Hot Spare Pool With Volumes
Increase file system availability after reboot
Increase overall file system availability after reboot, by adding UFS logging (transactional volume) to the system. Logging a file system reduces the amount of time that the fsck command has to run when the system reboots.
About File System Logging
