# metadetach d0 d20 d0: submirror d20 is detached # metaroot /dev/dsk/c0t3d0s0 # reboot ... # metaclear -r d0 d0: Mirror is cleared d10: Concat/Stripe is cleared # metaclear d20 d20: Concat/Stripe is cleared |
In this example, root (/) is a two-way mirror named d0; its submirrors are d10 and d20, which are made of slices /dev/dsk/c0t3d0s0 and /dev/dsk/c1t3d0s0, respectively. The metastat command verifies that at least one submirror is in the “Okay” state. (A mirror with no submirrors in the “Okay” state must first be repaired.) Submirror d20 is detached to make d0 a one-way mirror. The metaroot command is then run, using the rootslice from which the system is going to boot. This command edits the /etc/system and /etc/vfstab files to remove information that specifies the mirroring of root (/). After a reboot, the metaclear -r command deletes the mirror and the other submirror, d10. The last metaclear command clears submirror d20.
