Solaris 64-bit Developer's Guide
What's New for Applications
Most of the new features of the 64–bit environment are extensions of generic 32–bit interfaces, though several new features are unique to 64–bit environments.
64-bit: ABI Features
64-bit applications are described using Executable and Linking Format (ELF64), which allows large applications and large address spaces to be described completely.
ABI Features: SPARC V9
The SPARC Compliance Definition, Version 2.4, contains details of the SPARC V9 ABI. It describes the 32-bit SPARC V8 ABI and the 64-bit SPARC V9 ABI. You can obtain this document from SPARC International at www.sparc.com.
Following is a list of the SPARC V9 ABI features.
Stack Bias
An important feature of the SPARC V9 ABI for developers is the stack bias. For 64-bit SPARC programs, a stack bias of 2047 bytes must be added to both the frame pointer and the stack pointer to get to the actual data of the stack frame. See the following figure.
Graphic
For more information on stack bias, please see the SPARC V9 ABI.
Address Space Layout: SPARC V9
For 64-bit applications, the layout of the address space is closely related to that of 32-bit applications, though the starting address and addressing limits are radically different. Like SPARC V8, the SPARC V9 stack grows down from the top of the address space, while the heap extends the data segment from the bottom.
The diagram below shows the default address space provided to a 64–bit application. The regions of the address space marked as reserved might not be mapped by applications. These restrictions might be relaxed on future systems.
Graphic
The actual addresses in the figure above describe a particular implementation on a particular machine, and are given for illustrative purposes only.
Placement of Text and Data
By default, 64-bit programs are linked with a starting address of 0x100000000. The whole program is above 4 gigabytes, including its text, data, heap, stack, and shared libraries. This helps ensure that 64-bit programs are correct by making it so the program will fault in the lower 4 gigabytes of its address space, if it truncates any of its pointers.
While 64-bit programs are linked above 4 gigabytes, you can still link them below 4 gigabytes by using a linker mapfile and the -M option to the compiler or linker. A linker mapfile for linking a 64-bit SPARC program below 4 gigabytes is provided in /usr/lib/ld/sparcv9/map.below4G.
See the ld(1) linker man page for more information.
Code Models
Different code models are available from the compiler for different purposes to improve performance and reduce code size in 64-bit SPARC programs. The code model is determined by the following factors:
The following table describes the different code models available for 64-bit SPARC programs.
Table 6–1 Code Model Descriptions
Code Model
Positionability
Code Size
Location
External Object Reference Model
abs32
Absolute
< 2 gigabytes
Low (low 32 bits of address space)
None
abs44
Absolute
< 2 gigabytes
Middle (low 44 bits of address space)
None
abs64
Absolute
< 2 gigabytes
Anywhere
None
pic
PIC
< 2 gigabytes
Anywhere
Small (<= 1024 external objects)
PIC
PIC
< 2 gigabytes
Anywhere
Large (<= 2**29 external objects)
Shorter instruction sequences can be achieved in some instances with the smaller code models. The number of instructions needed to do static data references in absolute code is the fewest for the abs32 code model and the most for the abs64 code model, while abs44 is in the middle. Likewise, the pic code model uses fewer instructions for static data references than the PIC code model. Consequently, the smaller code models can reduce the code size and perhaps improve the performance of programs that do not need the fuller functionality of the larger code models.
To specify which code model to use, the -xcode=<model> compiler option should be used. Currently, for 64–bit objects, the compiler uses the abs64 model by default. You can optimize your code by using the abs44 code model; you will use fewer instructions and still cover the 44-bit address space that the current UltraSPARC platforms support.
See the SPARC V9 ABI and compiler documentation for more information on code models.
Note –
A program compiled with the abs32 code model must be linked below 4 gigabytes using the -M /usr/lib/ld/sparcv9/map.below4G option.
