The capabilities of the SolarisTM operating environment continue to expand to meet customer needs. The Solaris operating environment was designed to fully support both the 32–bit and 64-bit architectures. It provides an environment for building and running 64-bit applications that can use large files and large virtual address spaces. At the same time, it continues to provide maximum source and binary compatibility and interoperability for 32-bit applications. In fact, most of the system commands that run and have been built on the Solaris 64-bit implementation are 32-bit programs.
The major differences between the 32-bit and the 64-bit application development environments are that 32-bit applications are based on the ILP32 data model, where ints, longs, and pointers are 32 bits, while 64-bit applications are based on the LP64 model, where longs and pointers are 64 bits and the other fundamental types are the same as in ILP32.
Most applications can remain as 32-bit programs with no changes required. Conversion is necessary only if the application has one or more of the following requirements:
Needs more than 4 gigabytes of virtual address space
Reads and interprets kernel memory using libkvm, /dev/mem, or /dev/kmem
Uses a library that has only a 64-bit version
Needs full 64-bit registers to do efficient 64-bit arithmetic
Specific interoperability issues can also require code changes. For example, if your application uses files larger than 2 gigabytes, you might want to convert it to 64-bit.
In some cases, it is better to convert applications to 64-bit for performance reasons. For example, you might need the 64-bit registers to do efficient 64-bit arithmetic or you might want to take advantage of other performance improvements that a 64–bit instruction set provides.
This document is written for C and C++ developers and provides guidance on how to determine whether an application is 32-bit or 64-bit. It lists the similarities and differences between the 32-bit and 64-bit application environments, explains how to write code that is portable between the two environments, and describes the tools provided by the operating system for developing 64-bit applications.
This book is organized into the following chapters.
Chapter 1, 64–bit Computing, “64–bit Computing,” describes the motivation behind 64–bit computing and gives an overview of the benefits of 64–bit applications.
Chapter 2, When to Use 64–bit, “When to Use 64–bit,” explains the differences between the Solaris 32-bit and 64-bit build and runtime environments. It is written to help the application developer determine if and when it is appropriate to convert code to be 64-bit safe.
Chapter 3, Comparing 32–bit and 64–bit Interfaces, “Comparing 32–bit and 64–bit Interfaces,” focuses on the similarities between 32-bit and 64-bit applications and interfaces.
Chapter 4, Converting Applications, “Converting Applications,” describes how to convert current 32–bit code to 64-bit safe code and the tools available for making this process easier. The focus of this chapter is on writing portable code. It applies to converting existing applications or writing new applications capable of running in both 32-bit and 64-bit environments.
Chapter 5, The Development Environment, “The Development Environment,” focuses on the build environment, including headers, compilers, and libraries, as well as packaging guidelines and debugging tools.
Chapter 6, Advanced Topics, “Advanced Topics,” is an overview of 64–bit systems programming, the ABI, and some performance issues.
Appendix A, Changes in Derived Types, “Changes in Derived Types,” highlights many of the derived types that have changed in the 64-bit application development environment.
Appendix B, Frequently Asked Questions (FAQs), “Frequently Asked Questions,” provides answers to the most commonly asked questions about the 64-bit implementation and application development environment.
For further reading, the following are recommended:
American National Standard for Information Systems Programming Language - C, ANSI X3.159-1989
SPARC Architecture Manual, Version 9, SPARC International
SPARC Compliance Definition, Version 2.4, SPARC International
Large Files in Solaris: A White Paper, Part No: 96115-001
Solaris 8 Reference Manual
Writing Device Drivers, Part No: 805–7378
Sun WorkShop C User's Guide, Version 5.0, Part No: 805–4952
The docs.sun.comSM Web site enables you to access Sun technical documentation online. You can browse the docs.sun.com archive or search for a specific book title or subject. The URL is http://docs.sun.com.
The following table describes the typographic changes used in this book.
Table P–1 Typographic Conventions|
Typeface or Symbol |
Meaning |
Example |
AaBbCc123 | The names of commands, files, and directories; on-screen computer output |
Edit your .login file. Use ls -a to list all files. machine_name% you have mail. |
AaBbCc123 | What you type, contrasted with on-screen computer output | machine_name% su Password: |
AaBbCc123 | Command-line placeholder: replace with a real name or value |
To delete a file, type rm filename. |
AaBbCc123 |
Book titles, new words or terms, or words to be emphasized. |
Read Chapter 6 in User's Guide. These are called class options. Do not save changes yet. |
The following table shows the default system prompt and superuser prompt for the C shell, Bourne shell, and Korn shell.
Table P–2 Shell Prompts|
Shell |
Prompt |
| C shell prompt | machine_name% |
| C shell superuser prompt | machine_name# |
| Bourne shell and Korn shell prompt | $ |
| Bourne shell and Korn shell superuser prompt | # |
The term “IA” refers to the Intel 32–bit processor architecture, which includes the Pentium, Pentium Pro, Pentium II, Pentium II Xeon, and Pentium III processors and compatible microprocessor chips made by AMD and Cyrix.
