Solaris Modular Debugger Guide
dcmds
[ address ] ::softint
Display the soft interrupt vector structure at the specified address, or display all the active soft interrupt vectors. The pending count, PIL, argument, and handler function for each structure is displayed.
::ttctl
Display trap trace control records. The trap trace facility is available only in DEBUG kernels.
[ cpuid ] ::ttrace [-x]
Display trap trace records in reverse chronological order. The trap trace facility is available only in DEBUG kernels. If an explicit dot value is specified, this is interpreted as a CPU ID number, and the output is restricted to the buffer from that CPU. If the -x option is specified, the complete raw record is displayed.
[ address ] ::xc_mbox
Display the cross-call mailbox at the specified address, or format all the cross-call mailboxes that have pending requests.
::xctrace
Format and display cross-call trace records in reverse chronological order that are related to CPU cross-call activity. The cross-call trace facility is available only in DEBUG kernels.
