STREAMS Programming Guide
STREAMS Interrupt Handlers
Most hardware drivers have an interrupt handler routine. You must supply an interrupt routine for the device's driver. The interrupt handling for STREAMS drivers is not fundamentally different from that for other device drivers. Drivers usually register interrupt handlers in their attach(9E)entry point, using ddi_add_intr(9F). Drivers unregister the interrupt handler at detach time using ddi_remove_intr(9F).
The system also supports software interrupts. The routines ddi_add_softintr(9F) and ddi_remove_softintr(9F) register and unregister (respectively) soft-interrupt handlers. A software interrupt is generated by calling ddi_trigger_softintr(9F).
See Writing Device Drivers for more information.
