Example 8–3 is an example of a read device interrupt handler.
#include <sys/types.h>
#include <sys/param.h>
#include <sys/stream.h>
buffcall_id_t id; /* hold id val for unbufcall */
dev_rintr(dev)
/* process incoming message ... */
/* allocate new buffer for device */
dev_re_load(dev);
* Reload device with a new receive buffer
dev_re_load(dev)
mblk_t *bp;
id = 0; /* begin with no waiting for buffers */
if ((bp = allocb(DEVBLKSZ, BPRI_MED)) == NULL) {
cmn_err(CE_WARN,"dev:allocbfailure(size%d)\n",
DEVBLKSZ);
* Allocation failed. Use bufcall to
* schedule a call to ourselves.
id = bufcall(DEVBLKSZ,BPRI_MED,dev_re_load,dev);
return;
/* pass buffer to device ... */
See Chapter 12, Multithreaded STREAMS for more information on the uses of unbufcall(9F). These references to unbufcall are protected by MT locks.
Because bufcall(9F) can fail, there is still a chance that the device will hang. A better strategy if bufcall(9F) fails is to discard the current input message and resubmit that buffer to the device. Losing input data is preferable to the device hanging.
