The following example shows the code for the upper multiplexer write service procedure:
static int muxuwsrv(queue_t *q)
mblk_t *mp;
struct mux *muxp;
muxp = (struct mux *)q->q_ptr;
if (!muxbot) {
flushq(q, FLUSHALL);
return (0);
if (muxerr) {
return (0);
while (mp = getq(q)) {
if (canputnext(muxbot))
putnext(muxbot, mp);
else {
putbq(q, mp);
return(0);
return (0);
As long as there is a stream still linked under the multiplexer and there are no errors, the service procedure will take a message off the queue and send it downstream, if flow control allows.
