adjmsg(9F)
Trim bytes in a message
allocb(9F)
Allocate a message block
backq(9F)
Get pointer to the queue behind a given queue
bcanput(9F)
Test for flow control in a given priority
band
bufcall(9F)
Recover from failure of allocb(9F)
canput(9F)
Test for room in a queue
copymsg(9F)
Copy a message
datamsg(9F)
Test whether message is a data message
dupb(9F)
Duplicate a message block descriptor
dupmsg(9F)
Duplicate a message
enableok(9F)
Re-allow a queue to be scheduled for service
esballoc(9F)
Allocate message and data blocks
flushband(9F)
Flush messages in a given priority band
flushq(9F)
Flush a queue
freeb(9F)
Free a message block
freemsg(9F)
Free all message blocks in a message
freezestr(9F)
Disable changes to the state of the stream
getq(9F)
Get a message from a queue
insq(9F)
Put a message at a specific place in a queue
linkb(9F)
Concatenate two messages into one
msgdsize(9F)
Get the number of data bytes in a message
noenable(9F)
Prevent a queue from being scheduled
otherq(9F)
Get pointer to the queue's partner queue
pullupmsg(9F)
Concatenate and align bytes in a message
putbq(9F)
Return a message to the beginning of a queue
putctl(9F)
Put a control message
putctl1(9F)
Put a control message with a one-byte parameter
putnext(9F)
Put a message to the next queue
putq(9F)
Put a message on a queue
qbufcall(9F)
Call a function when a buffer becomes available
qprocsoff(9F)
Turn off queue processing
qprocson(9F)
Turn on queue processing
qreply(9F)
Send a message on a stream in the reverse direction
qsize(9F)
Find the number of messages on a queue
qtimeout(9F)
Execute a function after a specified length of time
qunbufcall(9F)
Cancel a pending qbufcall request
quntimeout(9F)
Cancel a pending qtimeout request
qwait(9F)
Perimeter wait routine
qwait_sig(9F)
qwriter(9F)
Asynchronous perimeter upgrade
RD(9F)
Get pointer to the read queue
rmvb(9F)
Remove a message block from a message
rmvq(9F)
Remove a message from a queue
strlog(9F)
Submit messages for logging
strqget(9F)
Obtain information on a queue or a band of the queue
strqset(9F)
Change information on a queue or a band of the queue
testb(9F)
Check for an available buffer
unbufcall(9F)
Cancel bufcall request
unfreezestr(9F)
Enable changes to the state of the stream
unlinkb(9F)
Remove a message block from the head of a message
WR(9F)
Get pointer to the write queue
