STREAMS Programming Guide
Line-Discipline Module
In the pseudo-TTY subsystem, the line discipline module is pushed on the slave side to present the user with the terminal interface.
ldterm(7M) can turn off the processing of the c_iflag, c_oflag, and c_lflag fields to allow processing to take place elsewhere. The ldterm(7M) module can also turn off all canonical processing when it receives an M_CTL message with the MC_NO_CANON command to support remote mode. Although ldterm(7M) passes through messages without processing them, the appropriate flags are set when an ioctl(2), such as TCGETA or TCGETS, is issued to indicate that canonical processing is being performed.
Figure C–2 Pseudo-TTY Subsystem Architecture
Diagram shows the client and server streams in a pseudo-TTY subsystem.
