Complex Text Layout (CTL) extensions enable Motif APIs to support writing systems that require complex transformations between logical and physical text representations, such as those required for Arabic, Hebrew, and Thai. CTL Motif provides character shaping, such as ligatures, diacritics, and segment ordering , and supports the transformation of static and dynamic text widgets. It also supports right-to-left and left-to-right text orientation and tabbing for dynamic text widgets. Because text rendering is handled through the rendition layer, other widget libraries can be easily extended to support CTL.
To leverage the new features, users must have the Portable Layout Services (PLS) library and the appropriate language engine. CTL uses PLS as the interface to the language engine, and uses the language engine to transform text before the text is rendered. Applications that support CTL must include additional resources, as described in the CTL documentation.
Specifically, XomCTL supports the following complex language shaping and reordering features provided by underlying locale-dependent PLS module transformations:
The CTL architecture is organized as shown in Figure 6–1. Dt Apps at the top of the stack employs Motif CTL functionality for rendering text. Motif in turn interfaces with locale-specific language engines using PLS, and performs transformations to support positional variation, numeral shaping, and so on.
The CTL architecture is built to support new languages by adding a new locale-specific engine. In other words, support for Thai and Vietnamese can be added without altering Motif or Dt Apps.
XomCTL (Complex Text Layout support in X Library Output Module) allows all pure X Windows applications (such as an X-based terminal emulator) to have CTL support. XomCTL provides a full-featured Open Source XI18N implementation including X11 dumb font support.
The following XOC resources are provided by the Solaris 9 environment:
Enables user to set the text buffer on which CTL operation needs to be performed.
Provides number of glyphs for the text in the text buffer.
Same as XmNLayoutModifier of Motif.
Same as PLS Property, input-to-output and output-to-input.
Descriptions of these may be obtained from the specification of X/Open or PLS Portable Layout Services.
The following chages to Motif support the CTL technology:
Controls object layout.
Specifies the direction in which the system displays characters of a string.
Adds new pseudo resources to XmRendition.
Affects the layout behavior of the text associated with the XmRendition.
Returns the layout modifier string of a rendition layout object.
Returns the value of the current layout object settings of the rendition associated with the widget.
Sets the layout modifier values for the layout object tied to its rendition.
Modifies the layout object settings of a rendition associated with the widget.
Creates a compound string.
The XmNlayoutDirection resource [See section 11.3 of the Motif Programmer's Guide (Release 2.1) for an overview of XmNlayoutDirection, and especially for a description of the interaction between XmStringDirection and XmNlayoutDirection.] controls object layout. It interacts with the orientation value of the LayoutObject in the manner described below.
When XmNlayoutDirection is specified as XmDEFAULT_DIRECTION, then the widget's layout direction is set at creation time from the governing pseudo-XOC. In the case of dynamic text (XmText and XmTextField), the governing pseudo-XOC is the one that is associated with the XmRendition used for the widget. In the case of static text (XmList, XmLabel, XmLabelG), the layout direction is set from the first compound string component that specifies a direction. This specification happens in one of two ways:
The component is of type XmSTRING_COMPONENT_LAYOUT_PUSH or XmSTRING_COMPONENT_DIRECTION.
The component is of type XmSTRING_COMPONENT_LOCALE_TEXT, XmSTRING_COMPONENT_WIDECHAR_TEXT, or XmSTRING_COMPONENT_TEXT, from the component's associated XmRendition's and associated LayoutObject.
When XmNlayoutDirection is not specified as XmDEFAULT_DIRECTION, and the XmNlayoutModifier @ls orientation value is not specified explicitly in the layout modifier string, then the XmNlayoutDirection value is passed through to the XOC and its LayoutObject.
If both XmNlayoutDirection and the XmNlayoutModifier @ls orientation value are explicitly specified, then the behavior is mixed. The XmNlayoutDirection controls widget object layout, and the XmNlayoutModifier @ls orientation value controls layout transformations.
See CAE Specification: Portable Layout Services: Context-dependent and Directional Text. The Open Group: Feb 1997; ISBN 1-85912-142-X; document number C616 for a description of portable functions for handling context-dependent and bidirectional text transformations as a logical extension to the existing POSIX locale model. The document is intended for system and application programmers who want to provide support for complex-text languages.
XmStringDirection is the data type used to specify the direction in which the system displays characters of a string.
The XmNlayoutDirection resource sets a default rendering direction for any compound string (XmString) that does not have a component specifying the direction of that string. Therefore, to set the layout direction, you need to set the appropriate value for the XmNlayoutDirection resource. You do not need to create compound strings with specific direction components. When the application renders an XmString, the application should look to see if the string was created with an explicit direction (XmStringDirection). If there is no direction component, the application should check the value of the XmNlayoutDirection resource for the current widget and use that value as the default rendering direction for the XmString.
CTL adds the new pseudo resources to XmRendition listed in the following table:
Table 6–1 New Resources in XmRendition|
 Name  |
 Class/Type  |
 Access  |
 Default Value  |
 XmNfontType  |
 XmCFontType/XmFontType  |
 CSG  |
 XmAS_IS  |
 XmNlayoutAttrObject  |
 XmClayoutAttrObject/String  |
 CG  |
 NULL  |
 XmNlayoutModifier  |
 XmClayoutModifier/String  |
 CSG  |
 NULL  |
Specifies the type of the Rendition font object. For CTL, the value of this resource must be the XmFONT_IS_XOC value. If the value does not match, then the XmNlayoutAttrObject and XmNlayoutModifier resources are ignored.
When the value of this resource is XmFont_IS_XOC, and if the XmNfont resource is not specified, then at create time the value of the XmNfontName resource is converted into an XOC object in either the locale specified by the XmNlayoutAttrObject resource or the current locale. Furthermore, the value of the XmNlayoutModifier resource is passed through to any layout object associated with the XOC.
Specifies the layout AttrObject argument. This resource is used to create the layout object associated with the XOC associated with this XmRendition. Refer to the layout services m_create_layout() specification for the syntax and semantics of this string. See the description of XmNfontType for an explanation of the interaction between the Layout Modifier Orientation output value and the XmNlayoutDirection widget resource.
Specifies the layout values to be passed through to the layout object used with the XOC for this XmRendition. For the syntax and semantics of this string, see CAE Specification.
Setting this resource using XmRendition{Retrieve,Update} causes the string to be passed through to the layout object associated with the XOC associated with this rendition. This is the mechanism for configuring layout services dynamically. Unpredictable behavior can result if the Orientation, Context, TypeOfText, TextShaping, or ShapeCharset are changed.
The XmNlayoutModifier affects the layout behavior of the text associated with the XmRendition. For example, if the layout default treatment of numerals is NUMERALS_NOMINAL, the user can change to NUMERALS_NATIONAL by setting XmNlayoutModifier to @ls numerals=nominal:national, or @ls numerals=:national.
The layout values can be classified into the following groups:
Encoding description-TypeOfText, TextShaping, ShapeCharset (and locale codeset)
TypeOfText is essentially segment ordering and can be illustrated with opaque blocks. Modifying these values dynamically, through the rendition object, is not usually meaningful, and is almost certain to result in unpredictable behavior.
Layout behavior-Orientation, Context, ImplicitAlg, Swapping, and Numerals. Orientation and Context should not be modified dynamically. You can safely modify ImplicitAlg, Swapping, and Numerals.
Xm CTL extends XmText and XmTextField by adding a parallel set of movement and deletion actions that operate visually, patterned after the Motif 2.0 CSText widget. The standard Motif 2.1 Text and TextField do not distinguish between logical and physical order: next and forward mean “to the right,” while previous and backward mean “to the left.” CSText, however, makes the proper distinction and defines a new set of actions with strictly physical names (for example, left-character(), delete-right-word(), and so on). All of these action routines are defined to be sensitive to the XmNlayoutDirection of the widget and to call the appropriate next- or previous- action. The Xm CTL extensions are slightly more complex than the CSText extensions. The Xm CTL extensions are sensitive not to the global orientation of the widget, but to the specific directionality of the physical characters surrounding the cursor, as determined by the pseudo-XOC, including neutral stabilization.
There is also a new resource to control selection policy, to provide a rendition tag, and to control alignment.
The set of new Xm CTL actions is roughly the cross product of {Move,Delete,Kill} by {Left,Right} by {Character,Word}, and is listed below.
Table 6–2 New Resources in Xm CTL|
 Name  |
 Class/Type  |
 Access  |
 Default Value  |
 XmNrenditionTag  |
 XmCRenditionTag/XmRString  |
 CSG  |
 XmFONTLIST_DEFAULT_TAG  |
 XmNalignment  |
 XmCAlignment/XmRAlignment  |
 CSG  |
 XmALIGNMENT_BEGINNING  |
 XmNeditPolicy  |
 XmCEditPolicy/XmREditPolicy  |
 CSG  |
 XmEDIT_LOGICAL  |
Specifies the rendition tag of the XmRendition that is in the XmNrenderTable resource, used for this widget.
Specifies the text alignment used in the widget. Only XmALIGNMENT_END and XmALIGNMENT_CENTER are supported.
Specifies the editing policy used for the widget, either XmEDIT_LOGICAL or XmEDIT_VISUAL. In the case of XmEDIT_VISUAL, selection, cursor movement, and deletion are in a visual style. Setting this resource also changes the translations for the standard keyboard movement and deletion events either to the new “visual” actions list or to the existing logical actions.
The forward-cell() and backward-cell() actions query the orientation of the character in the direction specified. If the direction is left-to-right, they call the corresponding next-/forward- or previous-/backward- variants:
The actions determine the orientation of characters by using the Layout Services transformation OutToInp and Property buffers (for the nesting level). The widget's behavior is therefore dependent on the locale-specific transformation. If the information in the OutToInp or, especially, Property buffers is inaccurate, the widget might behave unexpectedly. Moreover, as the locale-specific modules fall outside of the scope of this specification, bi-directional editing behavior can differ from platform to platform for the same text, application, resource values, and LayoutObject configuration.
The visual mode actions result in a display of cell-based behavior. The logical mode actions result in logical character-based behavior. For example, the delete-right-character() operation deletes the input buffer characters that correspond to the display cell. That is, one input buffer character whole LayoutObject transformation “property” byte “new cell indicator” is 1, and all of the succeeding characters whose “new cell indicator” [For more information on the Property buffer, see the specification for m_transform_layout() in CAE Specification.] is 0.
Similarly, for backward-character(), the insertion point is moved backward one character in the input buffer, and the cursor is redrawn at the visual location corresponding to the associated output buffer character. This means that several keystrokes are required to move across a composite display cell; the cursor does not actually change display location as the insertion point moves across input buffer characters whose “new cell indicator” is 0 (that is, diacritics or ligature fragments).
This means that deletion operates either from the logical/input buffer side, or from the display cell level of the physical/output side. There is no mode for a strict, physical character-by-character deletion, since there is no one-to-one correspondence between the input and output buffers. A given physical character can represent only a fragment of a logical character, for example.
The follwoing list describes the XmText action routines.
If the XmNeditPolicy is XmEDIT_LOGICAL and is called without arguments, the insertion cursor moves back logically by a character. If the insertion cursor is at the beginning of the line, the insertion cursor moves to the logical last character of the previous line, if one exists. Otherwise, the insertion cursor position doesn't change.
If the XmNeditPolicy is XmEDIT_VISUAL, then the cursor moves to the left of the cursor position. If the insertion cursor is at the beginning of the line, then it moves to the end character of the previous line, if one exists.
If left-character() is called with an extend argument, the insertion cursor moves, as in the case of no argument, and extends the current selection.
The left-character() action produces calls to the XmNmotionVerifyCallback procedures with the reason value XmCR_MOVING_INSERT_CURSOR. If called with an extend argument, this action can produce calls to the XmNgainPrimaryCallback procedures. See the callback description in the Motif Programmer's Reference for more information.
If the XmNeditPolicy is XmEDIT_LOGICAL and is called without any arguments, it moves the insertion cursor logically forward by a character. If the insertion cursor is at the logical end of the line, it moves the insertion cursor to the logical starting of the next line, if one exists.
If the XmNeditPolicy is XmEDIT_VISUAL, then the cursor moves to the right of the cursor position. If the insertion cursor is at the end of the line, it moves the insertion cursor to the starting of the next line, if one exists.
If called with an argument of extend, it moves the insertion cursor, as in the case of no argument, and extends the current selection.
The right-character() action produces calls to the XmNmotionVerifyCallback procedures with the reason value XmCR_MOVING_INSERT_CURSOR. If called with extend argument, this can produce calls to the XmNgainPrimaryCallback procedures. See the callback description in the Motif Programmer's Reference for more information.
If the XmNeditPolicy is XmEDIT_LOGICAL and is called without any arguments, it moves the insertion cursor to the logical starting of the logical succeeding word, if one exists; otherwise, it moves to the logical end of the current word. If the insertion cursor is at the logical end of the line or in the logical last word of the line, it moves the cursor to the logical first word in the next line, if one exists; otherwise, it moves to the logical end of the current word.
If the XmNeditPolicy is XmEDIT_VISUAL and is called without arguments, it moves the insertion cursor to the first nonwhite space character after the first white space character to the right or after the end of the line.
The left-word() action produces calls to the XmNmotionVerifyCallback procedures with the reason value XmCR_MOVING_INSERT_CURSOR. If called with extend argument, this can produce calls to the XmNgainPrimaryCallback procedures. See the callback description in the Motif Programmer's Reference for more information.
If the XmNeditPolicy is XmEDIT_LOGICAL, it is equivalent to delete-previous-char(). If the XmNeditPolicy is XmEDIT_VISUAL, then in normal mode, if there is a non-null selection, it deletes the selection; otherwise it deletes the character left of the insertion cursor. In add mode, if there is a non-null selection, the cursor is not disjointed from the selection and XmNpendingDelete is set to True, it deletes the selection; otherwise, it deletes the character left of the insertion cursor. This can impact the selection.
The delete-left-character() action produces calls to the XmNmodifyVerifyCallback procedures with reason value XmCR_MODIFYING_TEXT_VALUE and the XmNvalueChangedCallback procedures with reason value XmCR_VALUE_CHANGED.
If the XmNeditPolicy is XmEDIT_VISUAL, it is equivalent to delete-next-character(). If the XmNeditPolicy is XmEDIT_VISUAL, then in normal mode, if there is a non-null selection, it deletes the selection; otherwise, it deletes the character right of the insertion cursor. In add mode, if there is a non-null selection and the cursor is not disjointed from the selection, the XmNpendingDelete is set to True and the selection is deleted; otherwise, the character right of the insertion cursor is deleted. This can impact the selection.
The delete-right-character() action produces calls to the XmNmodifyVerify-Callback procedures with reason value XmCR_MODIFYING_TEXT_VALUE, and the XmNvalue-ChangedCallback procedures with reason value XmCR_VALUE_CHANGED.
A few cell-based routines are implemented to support character composition, ligatures, and diacritics. In other words, two or more characters might be represented by a single glyph occupying one presentation cell.
The XmText cell action routines are as follows:
Moves the insertion cursor back one cell. If the XmNeditPolicy is XmEDIT_LOGICAL, then the insertion cursor is moved to the start of the cell that precedes the current cell logically, if one exists; otherwise, it moves to the start of the current cell.
If the XmNeditPolicy is XmEDIT_VISUAL, then the cursor moves to the start of cell to the left of the cursor, if one exists. The prev-cell() action produces calls to the XmNmotionVerifyCallback procedures with the reason value XmCR_MOVING_INSERT_CURSOR. If called with an extend argument, this can produce calls to the XmNgainPrimaryCallback procedures. See the callback description in the Motif Programmer's Reference for more information.
Moves the insertion cursor to the start of the logical next cell, if one exists; otherwise it moves it to the end of the cell. If the XmNeditPolicy is XmEDIT_LOGICAL, then the cursor moves forward one cell.
If the XmNeditPolicy is XmEDIT_VISUAL, then the cursor moves to the start of the cell to the right of the cursor position, if one exists; otherwise, it moves to the end of the current cell. The forward-cell() action produces calls to the XmNmotionVerifyCallback procedures with the reason value XmCR_MOVING_INSERT_CURSOR. If called with an extend argument, this can produce calls to the XmNgainPrimaryCallback procedures. See the callback description in the Motif Programmer's Reference for more information.
XmTextFieldGetLayoutModifier() returns the layout modifier string that reflects the state of the layout object tied to its rendition.
The syntax for XmTextFieldGetLayoutModifier() is:
#include <Xm/TextF.h>String XmTextFieldGetLayoutModifier(Widget widget)
XmTextFieldGetLayoutModifier() accesses the value of the current layout object settings of the rendition associated with the widget. When the layout object modifier values are changed using a convenience function, the XmTextFieldGetLayoutModifier function returns the complete state of the layout object, not only the changed values.
XmTextFieldGetLayoutModifier() returns the layout object modifier values in the form of a string value.
XmTextGetLayoutModifier() returns the layout modifier string that reflects the state of the layout object tied to its rendition.
The syntax for XmTextGetLayoutModifier() is:
#include <Xm/Text.h>String XmTextGetLayoutModifier(Widget widget)
XmTextGetLayoutModifier accesses the value of the current layout object settings of the rendition associated with the widget. When the layout object modifier values are changed using a convenience function, the XmTextGetLayoutModifier function returns the complete state of the layout object, not just the changed values.
XmTextGetLayoutModifier returns the layout object modifier values in the form of a string value.
XmTextFieldSetLayoutModifier() sets the layout modifier values, which changes the behavior of the layout object tied to its rendition.
The syntax for XmTextFieldSetLayoutModifier() is:
#include <Xm/TextF.h>void XmTextFieldSetLayoutModifier(Widget widget,string layout_modifier)
XmTextFieldSetLayoutModifier modifies the layout object settings of a rendition associated with the widget. When the layout object modifier values are set using this convenience function, only the attributes specified in the input parameter are changed; the rest of the attributes remain untouched.
XmTextSetLayoutModifier() sets the layout modifier values, which changes the behavior of the layout object tied to its rendition.
The syntax for XmTextSetLayoutModifier() is:
#include <Xm/Text.h>void XmTextSetLayoutModifier(Widget widget,string layout_modifier)
XmTextSetLayoutModifier modifies the layout object settings of a rendition associated with the widget. When the layout object modifier values are set using this convenience function, only the attributes specified in the input parameter are changed; the rest of the attributes are left untouched.
XmStringDirectionCreate creates a compound string.
#include <Xm/Xm.h>XmString XmStringDirectionCreate(direction)XmStringDirection direction
XmStringDirectionCreate creates a compound string with a single component, a direction with the given value. On the other hand, the XmNlayoutDirection resource sets a default rendering direction for any compound string (XmString) that does not have a component specifying the direction for that string. Therefore, to set the layout direction, all you need to do is set the appropriate value for the XmNlayoutDirection resource. You need not create compound strings with specific direction components. When the application renders an XmString, it should look to see if the string was created with an explicit direction (XmStringDirection). If there is no direction component, the application should check the value of the XmNlayoutDirection resource for the current widget and use that value as the default rendering direction for the XmString.
The following table shows the UIL arguments.
Table 6–3 UIL| UIL Argument Name | Argument Type |
 String  |
 XmNlayoutModifier  |
 String  |
 XmNrenditionTag  |
 String  |
 XmNalignment  |
 Integer  |
 XmNeditPolicy  |
 Integer  |
The following sections show how to develop CTL applications.
The direction of a compound string is stored so that the data structure is equally useful for describing text in left-to-right languages such as English, Spanish, French, and German, or for text in right-to-left languages, such as Hebrew and Arabic. In Motif applications, you can set the layout direction using the XmNlayoutDirection resource from the VendorShell or MenuShell. Manager and Primitive widgets (as well as Gadgets) also have an XmNlayoutDirection resource. The default value is inherited from the closest ancestor with the same resource.
In the case of an XmText widget, you must specify the vertical direction as well. Setting the layoutDirection to XmRIGHT_TO_LEFT results in the string direction from right-to-left, but the cursor moves vertically down. If the vertical direction is important and you require top to bottom alignment, be sure to specify XmRIGHT_TO_LEFT_TOP_TO_BOTTOM, which specifies that the components are laid out from right-to-left first and then top-to-bottom, and results in the desired behavior.
Furthermore, the behavior of XmText and TextField widgets is influenced by the XmNalignment and XmNlayoutModifier resources of the XmRendition. These resources, in addition to XmNlayoutDirection, control the layout behavior of the Text widget. This behavior is illustrated in Figure 6–2.
The input string used in the figure is:
The XmNlayoutModifier string @ls orientation= setting values for the following figure are shown in the left column.
As the illustration shows, XmNAlignment dictates whether the text is flush right or left in conjunction with the layout direction. XmNlayoutModifier breaks the text into segments and arranges them left-to-right or right-to-left, depending on the orientation value. In other words, if the XmNlayoutDirection is XmRIGHT_TO_LEFT, and the XmNAlignment value is XmALIGNMENT_BEGINNING, the string is flush right.
The following code creates an XmLabel whose XmNlabelString is of the type XmCHARSET_TEXT, using the Rendition whose tag is “ArabicShaped.” The Rendition is created with an XmNlayoutAttrObject of “ar” (corresponding to the locale name for the Arabic locale) and a layout modifier string that specifies for the output buffer a Numerals value of NUMERALS_CONTEXTUAL and a ShapeCharset value of “unicode-3.0.”
The locale-specific layout module transforms its input text into an output buffer of physical characters encoded using the 16-bit Unicode 3.0 codeset. Because an explicit layout locale has been specified, this text is rendered properly independent of the runtime locale setting. In this example, the input is encoded in ISO 8859–6.
int n;
Arg args[10];
Widget w;
XmString labelString;
XmRendition rendition;
XmStringTag renditionTag;
XmRenderTable renderTable;
      /* alef lam baa noon taa - iso8859-6 */
labelString = XmStringGenerate("\307\344\310\346\312\", NULL
			                          XmCHARSET_TEXT, "ArabicShaped");
w = XtVaCreateManagedWidget("a label", xmLabelWidgetClass, parent,
                             XmNlabelString, labelString,
		                          XmNlabelType, XmSTRING,
                             NULL);
n = 0;
XtSetArg(args[n], XmNfontName, "-*-*-medium-r-normal-*-24-*-*-*-*-*-*");
      n++;
XtSetArg(args[n], XmNfontType, XmFONT_IS_XOC); n++;
XtSetArg(args[n], XmNlayoutAttrObject, "ar"); n++;
XtSetArg(args[n], XmNlayoutModifier,
          "@ls numerals=:contextual, shapecharset=iso8859-6"); n++;
renditionTag = (XmStringTag) "ArabicShaped";
rendition = XmRenditionCreate(w, renditionTag, argcs
s, n);
renderTable =
    XmRenderTableAddRenditions(NULL, &rendition, 1, XmREPLACE_MERGE);
XtVaSetValues(w, XmNrenderTable, renderTable, NULL);
The following code creates a TextField widget and a RenderTable with a single Rendition. Both the XmNlayoutAttrObject and XmNlayoutModifier pseudo resources have been left unspecified and therefore default to NULL. This value means the layout object associated with the Rendition belongs to the default locale, if one exists.
For this example to work properly, the locale must be set to one whose codeset is ISO 8859-6 and whose locale-specific layout module can support the IMPLICIT_BASIC algorithm. The Rendition's LayoutObject's ImplicitAlg value is modified through the Rendition's XmNlayoutModifier pseudo resource.
int n;
Arg args[10];
Widget w;
w = XmCreateTextField(parent, "text field", args, 0);
n = 0;
	XtSetArg(args[n], XmNfontName, "-*-*-medium-r-normal-*-24-*-*-*-*-*-*-*");
     n++;
rendition = XmRenditionCreate(w, renditionTag, args, n);
renderTable =
n = 0;
XtSetArg(args[n], XmNlayoutModifier, "@ls implicitalg=basic");
     n++;
XmRenditionUpdate(rendition, args, n);
Renditions and render tables should be specified in resource files for a properly internationalized application. When the render tables are specified in a file, the program binaries are made independent of the particular needs of a given locale, and can be easily customized to local needs.
Render tables are specified in resource files with the following syntax: resource_spec:[tag[,tag]*]
where tag is some string suitable for the XmNtag resource of a rendition.
This line creates an initial render table containing one or more renditions as specified. The renditions are attached to the specified tags:
resource_spec[*|.] rendition[*|.]resource_name:value
The following examples illustrate the CTL resources related to XmRendition that can be set using resource files. The fontType must be set to FONT_IS_XOC for the layout object to take effect. The layoutModifier specified using @ls is passed on to the layout object by the rendition object.
For a complete list of resources that can be set on the layout object using layoutModifier, see CAE Specification: Portable Layout Services: Context-dependent and Directional Text, The Open Group: Feb 1997; ISBN 1-85912-142-X; document number C616.
Before creating a render table, an application program must first have created at least one of the renditions that is part of the table. The XmRenderTableAddRenditions() function, as its name implies, is also used to augment a render table with new renditions. To create a new render table, call the XmRenderTableAddRenditions() function with a NULL argument in place of an existing render table.
The following code creates a render table using a rendition created with XmNfontType set to XmFONT_IS_XOC.
int n;
Arg args[10];
Widget w;
                            NULL);
n = 0;
     n++;
          "@ls numerals=nominal:contextual, shapecharset=iso8859-6"); n++;
renderTable =
    XmRenderTableAddRenditions(NULL, &rendition, 1, XmREPLACE);
To control the placement of text, a compound string can contain tab characters. To interpret those characters on display, a widget refers to the rendition in effect for that compound string, where it finds a list of tab stops. However, the dynamic widgets,TextField and XmText, do not use the tab resource of the rendition. Instead, they compute the tab width using the formula of 8*(width of character 0).
The tab measurement is the distance from the left margin of the compound string display. This distance is measured from the right margin, if the layout direction is right-to-left. Regardless of the direction of the text (Arabic right-to-left or English left-to-right), the tab inserts space to the right or left, as specified by the layout direction (XmNlayoutDirection).
The text following a tab is always aligned at the tab stop. The tab stop is calculated from the start of the widget, which in turn is influenced by XmNlayoutDirection. The behavior of the tabs and their interaction with directionality of the text and the XmNlayoutDirection of the widget is illustrated in the following figure.
The input for this illustration is abc\tdef\tgh.
The user makes a primary selection with mouse button 1. Pressing this button deselects any existing selection and moves the insertion cursor and the anchor to the position in the text where the button is pressed. Dragging while holding down mouxse button 1 selects all text between the anchor and the pointer position, deselecting any text outside the range.
The text selected is influenced by the resource XmNeditPolicy, which can be set to XmEDIT_LOGICAL or XmEDIT_VISUAL. If the XmNeditPolicy is set to XmEDIT_LOGICAL, and if the text selected is bi-directional, the selected text is not contiguous visually and is a collection of segments. This is because the text in the logical buffer does not have a one-to-one correspondence with the display.
As a result, the contiguous buffer of logical characters of bidirectional text, when rendered does not result in a continuous stream of characters. Conversely, when the XmNeditPolicy is set to XmEDIT_VISUAL, the selected text can be contiguous visually but is segmented in the logical buffer. Therefore, the sequence of selection, deletion, and insertion of bidirectional text at the same cursor point does not result in the same string.
The selection operation available with the mouse is also available with the keyboard. The combination of Shift-arrow keys allows the selection of text.
The selected text is influenced by the resource XmNeditPolicy, which can be set to XmEDIT_LOGICAL or XmEDIT_VISUAL. If the XmNeditPolicy is set to XmEDIT_LOGICAL, and if the selected text is bidirectional, the selected text is not contiguous visually. Because the text in the logical buffer does not have one-to-one correspondence with the display, the contiguous buffer of logical characters of bidirectional text, when rendered, does not result in a continuous stream of characters.
Conversely, when the XmNeditPolicy is set to XmEDIT_VISUAL, the text selected can be contiguous visually but is segmented in the logical buffer. Therefore, the sequence of selection, deletion, and insertion of bidirectional text at the same cursor point does not result in the same string.
The text resources that relate to geometry are the following:
The render table XmNrenderTable that the widget uses to select a font or font set and other attributes in which to display the text.
The Text and Textfield widgets can use only the font-related rendition resources, such as XmNfontType. These widgets can also specify the attributes of the layout object, such as XmNlayoutAttrObject, usually a locale identifier, and XmNlayoutModifier, which specifies the layout values to be passed through to the Layout Object associated with the XOC associated with this XmRendition.
A resource (XmNwordWrap) that specifies whether lines are broken at word boundaries when the text would be wider than the widget.
Breaking a line at a word boundary does not insert a new line into the text. In the case of cursive languages like Arabic, if the word length is greater than the widget length, the word is wrapped to the next line, but the first character in the next line is shaped independently of the previous character in the logical buffer.
The new Motif library enabled for Complex Text Layout (CTL) , is located in /usr/dt/lib/libXm.so.4. If your application links to libXm.so.3 it does not support CTL. ldd app_name shows the library to which the application is linking. To port the existing applications to enable CTL, you need to perform the following steps.
Add -DSUN_CTL to your Makefile. This flag is important and includes the necessary data structures to support CTL. This should be set during compilation.
Recompile the existing application. This recompilation automatically links with the CTL-enabled Motif library libXm.so.4
Add the XmText.translations resources to your application resource file. Without these resources, the layout engine of the locale does not launch.
Refer to the sample application attached to your documentation.
Use the font name that is available and appropriate to your locale in the fontName resource.
For example, if you want the cell-based character movement (Thai) in XmTextField or XmText widgets, set the translations of the corresponding widgets as follows:
XmText.translations: #override \n\
<Key>osfRight:forward-cell() \n\
<Key>osfLeft:backward-cell() \n\
<Key>osfDelete:delete-next-cell() \n\
<Key>osfBackSpace:delete-previous-cell() \n\
