This example creates a shared object file.
Add this font by adding the following lines to the corresponding sections of mp.conf. The following example shows how to add the TrueType font. The PCF font follows the same pattern except that you change the keyword to PCF instead of TrueType.
FontNameAlias jis0201R TrueType /home/fn/HG-Minchol.ttf FontGroup jis0201 TrueType jis0201R MapCode2Font 0x0020 0x007f jis0201 CnvCode2Font jis0201R _ttfjis0201 <.so path>
where the .so path points to the xu2jis0201.so file.
Invoking mp(1) with the changed mp.conf file causes the range 0x0020-0x007f to be printed in the new font. Map the other Japanese character ranges too with the same .so file, for example, the range 0x0000FF61 0x0000FF9F.
To maintain backward compatibility, the /usr/openwin/lib/locale/$LANG/print/prolog.ps file, if it exists, is used to create output in the current locale, where $LANG is one of the locale components. In that situation, no configuration file mechanism is used.
Refer to /usr/lib/lp/locale/en_US.UTF-8/mp/mp.conf, which is a sample mp.conf file.
