CTL adds the new pseudo resources to XmRendition listed in the following table:
Table 6–1 New Resources in XmRendition|
 Name  |
 Class/Type  |
 Access  |
 Default Value  |
 XmNfontType  |
 XmCFontType/XmFontType  |
 CSG  |
 XmAS_IS  |
 XmNlayoutAttrObject  |
 XmClayoutAttrObject/String  |
 CG  |
 NULL  |
 XmNlayoutModifier  |
 XmClayoutModifier/String  |
 CSG  |
 NULL  |
Specifies the type of the Rendition font object. For CTL, the value of this resource must be the XmFONT_IS_XOC value. If the value does not match, then the XmNlayoutAttrObject and XmNlayoutModifier resources are ignored.
When the value of this resource is XmFont_IS_XOC, and if the XmNfont resource is not specified, then at create time the value of the XmNfontName resource is converted into an XOC object in either the locale specified by the XmNlayoutAttrObject resource or the current locale. Furthermore, the value of the XmNlayoutModifier resource is passed through to any layout object associated with the XOC.
Specifies the layout AttrObject argument. This resource is used to create the layout object associated with the XOC associated with this XmRendition. Refer to the layout services m_create_layout() specification for the syntax and semantics of this string. See the description of XmNfontType for an explanation of the interaction between the Layout Modifier Orientation output value and the XmNlayoutDirection widget resource.
Specifies the layout values to be passed through to the layout object used with the XOC for this XmRendition. For the syntax and semantics of this string, see CAE Specification.
Setting this resource using XmRendition{Retrieve,Update} causes the string to be passed through to the layout object associated with the XOC associated with this rendition. This is the mechanism for configuring layout services dynamically. Unpredictable behavior can result if the Orientation, Context, TypeOfText, TextShaping, or ShapeCharset are changed.
The XmNlayoutModifier affects the layout behavior of the text associated with the XmRendition. For example, if the layout default treatment of numerals is NUMERALS_NOMINAL, the user can change to NUMERALS_NATIONAL by setting XmNlayoutModifier to @ls numerals=nominal:national, or @ls numerals=:national.
The layout values can be classified into the following groups:
Encoding description-TypeOfText, TextShaping, ShapeCharset (and locale codeset)
TypeOfText is essentially segment ordering and can be illustrated with opaque blocks. Modifying these values dynamically, through the rendition object, is not usually meaningful, and is almost certain to result in unpredictable behavior.
Layout behavior-Orientation, Context, ImplicitAlg, Swapping, and Numerals. Orientation and Context should not be modified dynamically. You can safely modify ImplicitAlg, Swapping, and Numerals.
