By default, CIM Workshop connects to a CIM Object Manager running on the local host in the root/cimv2 default namespace using the Remote Method Invocation (RMI) protocol. You can also point to a remote host that is running the CIM Object Manager.
At the system prompt, type:
% /usr/sadm/bin/cimworkshop |
The CIM Workshop Login dialog box displays.
Follow the instructions in the context-sensitive help to fill in the fields in the Login dialog box. Then click OK.
The CIM Workshop main window displays.
The CIM Workshop main window is divided into three panes:
Left pane – Displays the class inheritance tree of the current namespace.
Right pane – Displays the Properties, Methods, and Events tabs. When you select a class in the left pane, click one of these tabs in the right pane to get more information on the properties, methods, or events of the selected class.
Bottom pane – Displays notification when events occur to which you are subscribed.
