Solaris WBEM SDK Developer's Guide
Solaris Schema
An extension schema of the Common Model, the Solaris Schema specifically describes managed objects running in the Solaris operating environment.
When you install Solaris WBEM Services, the CIM Schema and the Solaris Schema MOF files populate the /usr/sadm/mof directory. These files are automatically compiled when the CIM Object Manager starts. The CIM Schema files, denoted by the CIM_ prefix, form standard CIM objects. The Solaris Schema extends the standard CIM Schema by describing Solaris objects. The MOF files that make up the Solaris Schema have the Solaris_ prefix.
Note -
The CIM and Solaris Schema is installed at file:/usr/sadm/lib/wbem/doc/mofhtml/index.html.
