A CIM property is a value that describes the characteristic of a CIM class. Properties can be thought of as a pair of functions, one that gets the property value and one that sets the property value.
The following example uses enumerateInstanceNames to return the names of all instances of the Solaris processor, getProperty to get the value of the current clockspeed for each instance, and println to print the current clockspeed values.
/* Create an object (CIMObjectPath) to store the name of the
Solaris_Processor class. */
CIMObjectPath cop = new CIMObjectPath("Solaris_Processor");
/* The CIM Object Manager returns an enumeration containing the names
of instances of the Solaris_Processor class. */
Enumeration e = cc.enumerateInstanceNames(cop);
/* Iterate through the enumeration of instance object paths.
Use the getProperty method to get the current clockspeed
value for each Solaris processor. */
while(e.hasMoreElements()) {
CIMValue cv = cc.getProperty(e.nextElement(CIMObjectPath),
"CurrentClockSpeed");
System.out.println(cv);
The following example sets the initial shell value for all Solaris_UserTemplate instances. This code segment uses enumerateInstanceNames to get the names of all instances of the Solaris_User Template, and setProperty to set the value of the initial shell for each instance.
CIMObjectPath cop = new CIMObjectPath("Solaris_UserTemplate");
of instances of the Solaris_UserTemplate class and
all its subclasses. */
Use the setProperty method to set the initial shell
value to /usr/bin/sh for each Solaris_UserTemplate instance. */
for (; e.hasMoreElements(); cc.setProperty(e.nextElement(),
"/usr/bin/sh", new CIMValue(new Integer(500))));
