Solaris WBEM SDK Developer's Guide
WQL Key Words
The Solaris WBEM SDK supports Level 1 WBEM SQL, which enables simple select operations without joins. The following table describes the supported WQL key words.
Table 5-2 Supported WQL Key Words
Key Word
Description
AND
Combines two Boolean expressions and returns TRUE when both expressions are TRUE.
FROM
Specifies the classes that contain the properties listed in a SELECT statement.
NOT
Comparison operator used with NULL.
OR
Combines two conditions. When more than one logical operator is used in a statement, OR operators are evaluated after AND operators.
SELECT
Specifies the properties that are used in a query.
WHERE
Narrows the scope of a query.
LIKE
Generates a result set based on a minimum amount of information provided.
SELECT Statement
You use the SELECT statement to retrieve instances of a single class and its subclasses. You can also specify the properties to retrieve and the conditions that must be met.
Note -
Currently, join operations are not supported.
The syntax for the SELECT statement is as follows:
SELECT list FROM class WHERE condition
The following table shows examples of using arguments in the SELECT clause to refine a search.
Table 5-3 Sample SELECT Statements
Example Query
Description
SELECT * FROM class
Selects all instances of the specified class and all of its subclasses. Each instance returned contains all the properties.
SELECT PropertyA FROM class
Selects all instances containing PropertyA of the specified class and all of its subclasses.
SELECT PropertyA, PropertyB FROM class WHERE PropertyB=20
Selects all instances of the specified class and all of its subclasses where PropertyB=20. Each returned instance contains only PropertyA and PropertyB.
FROM Clause
The FROM clause identifies the class in which to search for instances that match the query string. Only non-joined expressions are supported, which means that a valid WQL FROM clause includes only a single class.
The FROM clause is represented by the abstract class, fromExp. Currently NonJoinExp is the only direct subclass of fromExp. The NonJoinExp subclass represents FROM clauses with only one table (CIM class) to which the SELECT operation is applied.
WHERE Clause
The WHERE clause narrows the scope of a query. This clause contains a conditional expression, which can contain a property or key word, an operator, and a constant.
The syntax for a WHERE clause appended to a SELECT statement is as follows:
SELECT CIMinstance FROM CIMclass WHERE conditional_expression
The conditional_expression in the WHERE clause takes the following form:
property operator constant
The expression is composed of a property or key word, an operator, and a constant. You can append the WHERE clause to the SELECT statement using one of the following forms:
SELECT instance FROM class [[WHERE constant operator property]]
Valid WHERE clauses follow these rules:
Standard WQL Operators for WHERE Clauses
You can use the following standard WQL operators for a binary expression in the WHERE clause of a SELECT statement.
Table 5-4 WQL Operators for WHERE Clauses
Operator
Description
Equal to
Less than
Greater than
Less than or equal to
Greater than or equal to
Not equal to
