The Solaris_NamespaceAcl extends the Solaris_Acl base class, from which it inherits the string property capability with a default value r (read-only for all users). The Solaris_NamespaceAcl class defines this key property.
Property |
Data Type |
Purpose |
nspace |
string |
Identifies the namespace to which the access control list applies. Only one instance of the namespace ACL can exist in a namespace. |
Create an instance of the Solaris_namespaceAcl class. For example:
/* Create a namespace object initialized with root\security
(name of namespace) on the local host. */
CIMNameSpace cns = new CIMNameSpace("", "root\security");
// Connect to the root\security namespace as root.
cc = new CIMClient(cns, user, user_passwd);
// Get the Solaris_namespaceAcl class
cimclass = cc.getClass(new CIMObjectPath("Solaris_namespaceAcl");
// Create a new instance of the Solaris_namespaceAcl
class ci = cimclass.newInstance();
Set the capability property to the desired access rights. For example:
/* Change the access rights (capability) to read/write
to the root\molly namespace. */
ci.setProperty("capability", new CIMValue(new String("rw"));
ci.setProperty("nspace", new CIMValue(new String("root\molly"));
Update the instance. For example:
// Pass the updated instance to the CIM Object Manager cc.createInstance(new CIMObjectPath(), ci);
