WBEM log messages are stored in individual log files in the /var/sadm/wbem/log directory. The names of the log files, the directory in which the log files are stored, the log file size limit, the number of log files to store, and whether to forward messages to syslogd(1M) are properties that you manipulate with the singleton instance of the Solaris_LogServiceProperties class.
The format of each log entry is defined by the Solaris_LogEntry class, which is a subclass of CIM_LogRecord. You can find Solaris_LogEntry in Solaris_Device1.0.mof, and CIM_LogRecord in CIM_Device26.mof.
A log message includes the following elements:
Table 3-8 Log Message Elements|
Element |
Description |
Category |
Type of message – application, system, or security |
Severity |
Severity of the condition – warning or error |
Application |
Name of the application (or the provider) that is writing the log message |
User |
Name of the user who was using the application when the log message was generated |
Client Machine |
Name and IP address of the system that the user was on when the log message was generated |
Server Machine |
Name of the system on which the incident that generated the log message occurred |
Summary Message |
Descriptive summary of the incident |
Detailed Message |
Detailed description of the incident |
Data |
Contextual information that provides a better understanding of the incident |
SyslogFlag |
Boolean flag that specifies whether or not to send the message to syslogd(1M) |
This example creates an instance of Solaris_LogEntryand sets the instance.
public class CreateLog {
public static void main(String args[]) throws CIMException {
// Display usage statement if insufficient command line
// arguments are passed.
if (args.length < 3) {
System.out.println("Usage: CreateLog host username password
" + "[rmi|http]");
System.exit(1);
String protocol = CIMClient.CIM_RMI;
CIMClient cc = null;
CIMObjectPath cop = null;
BufferedReader d = new BufferedReader(new InputStreamReader
(System.in));
String input_line = "";
// Query user for number of records that need to be created.
System.out.print("How many log records do you want to write? ");
int num_recs = 0;
try {
num_recs = Integer.parseInt(d.readLine());
} catch (Exception ex) {
ex.printStackTrace();
System.exit(1);
// Over-arching try-catch block
try {
CIMNameSpace cns = new CIMNameSpace(args[0]);
UserPrincipal up = new UserPrincipal(args[1]);
PasswordCredential pc = new PasswordCredential(args[2]);
// Set up the transport protocol - set by default to RMI.
if (args.length == 4 && args[3].equalsIgnoreCase("http")) {
protocol = CIMClient.CIM_XML;
cc = new CIMClient(cns, up, pc, protocol);
Vector keys = new Vector();
CIMProperty logsvcKey = null;
// Prompt user for relevant info needed to create the
// log record.
System.out.println("Please enter the record Category: ");
System.out.println("\t(0)application, (1)security,
(2)system");
logsvcKey = new CIMProperty("category");
input_line = d.readLine();
logsvcKey.setValue(new CIMValue(Integer.valueOf
(input_line)));
keys.addElement(logsvcKey);
System.out.println("Please enter the record Severity:");
System.out.println("\t(0)Informational, (1)Warning,
(2)Error");
logsvcKey = new CIMProperty("severity");
(input_line)));
logsvcKey = new CIMProperty("Source");
System.out.println("Please enter Application Name:");
logsvcKey.setValue(new CIMValue(d.readLine()));
logsvcKey = new CIMProperty("SummaryMessage");
System.out.println("Please enter a summary message:");
logsvcKey = new CIMProperty("DetailedMessage");
System.out.println("Please enter a detailed message:");
logsvcKey = new CIMProperty("RecordData");
logsvcKey.setValue(
new CIMValue("0xfe 0x45 0xae 0xda random data"));
logsvcKey = new CIMProperty("SyslogFlag");
logsvcKey.setValue(new CIMValue(new Boolean(true)));
CIMObjectPath logreccop =
new CIMObjectPath("Solaris_LogEntry", keys);
CIMClass logClass = cc.getClass(logreccop);
CIMInstance ci = logClass.newInstance();
ci.setClassName("Solaris_LogEntry");
ci.setProperties(keys);
// System.out.println(ci.toString());
// Create as many instances of the record as requested.
for (int i = 0; i < num_recs; i++) {
cc.createInstance(logreccop, ci);
} catch (Exception e) {
System.out.println("Exception: "+e);
e.printStackTrace();
// close session.
if (cc != null) {
cc.close();
This example displays a list of log records.
public class ReadLog {
System.out.println("Usage: ReadLog host username password " +
"[rmi|http]");
System.exit(1);
CIMObjectPath serviceObjPath = null;
Vector inVec = new Vector();
Vector outVec = new Vector();
try {
cop = new CIMObjectPath("Solaris_LogEntry");
// Enumerate the list of instances of class Solaris_LogEntry
Enumeration e = cc.enumerateInstances(cop, true, false,
false, false, null);
// iterate over the list and print out each property.
for (; e.hasMoreElements(); ) {
System.out.println("---------------------------------");
CIMInstance ci = (CIMInstance)e.nextElement();
System.out.println("Log filename : " +
((String)ci.getProperty("LogName").getValue().
getValue()));
int categ =
(((Integer)ci.getProperty("Category").getValue().getValue()).
intValue());
if (categ == 0)
System.out.println("Category : Application Log");
else if (categ == 1)
System.out.println("Category : Security Log");
else if (categ == 2)
System.out.println("Category : System Log");
int severity =
(((Integer)ci.getProperty("Severity").getValue().getValue()).
intValue());
if (severity == 0)
System.out.println("Severity : Informational");
else if (severity == 1)
System.out.println("Severity : Warning Log!");
else if (severity == 2)
System.out.println("Severity : Error!!");
System.out.println("Log Record written by :" +
((String)ci.getProperty("Source").getValue().getValue()));
System.out.println("User : " +
((String)ci.getProperty("UserName").getValue().getValue()));
System.out.println("Client Machine : " +
((String)ci.getProperty("ClientMachineName").getValue().getValue()));
System.out.println("Server Machine : " +
((String)ci.getProperty("ServerMachineName").getValue().getValue()));
System.out.println("Summary Message : " +
((String)ci.getProperty("SummaryMessage").getValue().getValue()));
System.out.println("Detailed Message : " +
((String)ci.getProperty("DetailedMessage").getValue().getValue()));
System.out.println("Additional data : " +
((String)ci.getProperty("RecordData").getValue().getValue()));
boolean syslogflag =
((Boolean)ci.getProperty("SyslogFlag").getValue().getValue()).
booleanValue();
if (syslogflag == true) {
System.out.println("Record was written to syslog");
} else {
System.out.println("Record was not written to syslog");
// close session.
if (cc != null) {
cc.close();
