This following sample code implements the enumerateInstances and getInstance interfaces for the Ex_SimpleCIMInstanceProvider class. For brevity, this example implements the deleteInstance, createInstance, setInstance, and execQuery interfaces by throwing a CIMException.
For information on implementing the execQuery method, see “Parsing Queries”.
* "@(#)SimpleCIMInstanceProvider.java"
import javax.wbem.cim.*;
import javax.wbem.client.*;
import javax.wbem.provider.CIMProvider;
import javax.wbem.provider.CIMInstanceProvider;
import javax.wbem.provider.MethodProvider;
import java.util.*;
import java.io.*;
public class SimpleCIMInstanceProvider implements CIMInstanceProvider{
static int loop = 0;
public void initialize(CIMOMHandle cimom) throws CIMException {
public void cleanup() throws CIMException {
public CIMObjectPath[] enumerateInstanceNames(CIMObjectPath op,
CIMClass cc)
return null;
* enumerateInstances:
* The entire instances and not just the names are returned.
public CIMInstance[] enumerateInstances(CIMObjectPath op,
boolean localOnly,boolean includeQualifiers,
boolean includeClassOrigin,String[]
propertyList, CIMClass cc) throws CIMException
if (op.getObjectName().equalsIgnoreCase\
("Ex_SimpleCIMInstanceProvider"))
Vector instances = new Vector();
CIMInstance ci = cc.newInstance();
if (loop == 0){
ci.setProperty("First", new CIMValue("red"));
ci.setProperty("Last", new CIMValue("apple"));
// only include the properties that were requested
ci = ci.filterProperties(propertyList, includeQualifier,
includeClassOrigin);
instances.addElement(ci);
loop += 1;
} else {
ci.setProperty("First", new CIMValue("green"));
return (CIMInstance[])instances.toArray();
throw new CIMException(CIM_ERR_INVALID_CLASS);
public CIMInstance getInstance(CIMObjectPath op, boolean localOnly,
boolean includeQualifiers, boolean includeClassOrigin,
String[] propertyList, CIMClass cc) ) throws CIMException {
// we need to get the keys from the passed in object path, this
// will uniqeuly identify the instance we want to get
java.util.Vector keys = cop.getKeys();
// Since this is a contrived example we will simply place the keys
// into the instance and be done.
ci.setProperties(keys);
// if we had other non-key properties we should add them here.
ci = ci.filterProperties(propertyList, includeQualifiers,
return ci;
public CIMInstance[] execQuery(CIMObjectPath op, \
String query, String ql, CIMClass cc)
throw(new CIMException(CIMException.CIM_ERR_NOT_SUPPORTED));
public void setInstance(CIMObjectPath op, CIMInstance ci, boolean
includeQualifiers, String[] propertyList)
public CIMObjectPath createInstance(CIMObjectPath op, CIMInstance ci)
public void deleteInstance(CIMObjectPath cp) throws CIMException {
