Following is an example provider program that uses the query APIs to parse the WQL string passed to it by the execQuery method. This program parses the select expression in the query string, performs a deep enumeration of the class, and iterates through the instances in the enumeration, matching the query expression and select list to each instance. Finally, the program returns a vector containing the enumeration of the instances that match the query string.
* The execQuery method will support only limited queries
* based upon partial key matching. An empty Vector is
* returned if no entries are selected by the query.
* @param op The CIM object path of the CIM instance to be returned
* @param query The CIM query expression
* @param ql The CIM query language indicator
* @param cc The CIM class reference
* @return A vector of CIM object instances
* @version 1.19 01/26/00
* @author Sun Microsystems, Inc.
public CIMInstance[] execQuery(CIMObjectPath op,
String query,
String ql,
CIMClass cc)
throws CIMException {
Vector result = new Vector();
try {
SelectExp q = new SelectExp(query);
SelectList attrs = q.getSelectList();
NonJoinExp from = (NonJoinExp)q.getFromClause();
QueryExp where = q.getWhereClause();
CIMInstance[] v = enumerateInstances(op, false, true,
true, null, cc);
// filtering the instances
for (int i = 0; i < v.length; i++) {
if ((where == null) || (where.apply(v[i]) == true)) {
result.addElement(attrs.apply(v[i]));
} catch (Exception e) {
throw new CIMException(CIMException.CIM_ERR_FAILED, e.toString());
return (CIMInstance[])result.toArray();
} // execQuery
