Solaris WBEM SDK Developer's Guide
Provider Naming Conventions
You can include providers in a single Java class file or store each provider in a separate class. The provider name identifies the Java class that serves as the provider for the class. Currently, the CIM Object Manager supports only providers written in the Java language.
Provider and class names must follow these rules:
Note -
You must prepend “java:” to every provider qualifier to notify the CIM Object Manager that the provider is written in the Java language.
Follow standard Java class and package naming conventions to create your provider names. The prefix of a package name is written in lowercase ASCII letters and must be one of the top-level domain names (com, edu, gov, mil, net, org), or one of the English two-letter country codes specified in ISO Standards 3166, 1981.
Subsequent components of the package name will vary according to your organization's internal naming conventions. Such conventions might specify that certain directory name components are division, department, project, machine, or login names. For example, the provider name java:com.sun.wbem.cimom indicates the following:
